fishinpolejoe
- Virginia - southwest tip
Hey folks. I'm running a stock 96 XJ, 4wd, 4.0 HO, 277,000 + miles. For the last week or so the RPMs have been jumping up to 2,000 when I put it in park after driving it. It doesn't do it every time and it seems to happen at random. Doesn't matter if it's hot or cold etc. It seems to be happening more frequently as time goes on. I've also noticed that before it does this, the XJ wants to go without me pushing the gas. Tonight I had to hold the brake coming up my driveway when I usually have to give it a little gas. I knew it was going to rev up so I put it in Neutral instead of Park and it the RPM's hit 2500 and stayed there. I turn it off when it does this. I can re-start it right away and it will run normally.
I haven't had any work done to it recently, not even an oil change. Last thing I did was adjust the TV cable and I added some Lube Guard Instant Shudder Fix to the transmission fluid in an attempt to alleviate a TC issue. I wasn't having the RPM issue until weeks later.
Ideas?
Ideas?
