BarFlyFisherman
I found the following information on-line and have never seen it posted here. There are frequently questions about "what axle do I have?", so i though that I'd just post the relevant data to get the job done.
ONCE YOU HAVE LOCATED THE PART NUMBER AND AXLE CODE, YOU CAN USE THE DATA BELOW TO IDENTIFY WHAT YOU HAVE (or had before someone re-geared it)
PART # CODE YEAR FOUND ON THESE VEHICLES AXLE TYPE RATIO DIFFERENTIAL TYPE E 1986 Cherokee, Wagoneer & Comanche 35 3.54 NL K 1986 Cherokee, Wagoneer & Comanche 35 4.11 NL KK 1986 Cherokee, Wagoneer & Comanche 35 4.11 LS S 1984 - 85 Cherokee & Wagoneer 35 3.73 NL T 1984 - 86 Cherokee, Wagoneer & Comanche 35 3.31 NS SS 1984 - 85 Cherokee & Wagoneer 35 3.73 LS TT 1984 - 85 Cherokee & Wagoneer 35 3.31 LS
This code... means this axle... with this number of bolts holding the cover on... with this general differential housing shape... with this size ring gear... with these notes... Photo, diagram, sketch or cave drawing of the axle housing, cover or cover gasket. 20 Dana 20 rear axle Cover is very round when viewed from the back. VERY rare in early MJ's. Primarily found on CJ's, etc.- 8 Digit codes beginning with "5" are Daimler-Chrysler numbers.
- 10 digit codes beginning with "8" are AMC / Chrysler Codes prior to Daimler-Benz.
- 1991-1997 Daimler-Chrysler codes:
- PART # CODE - YEAR - VEHICLE - AXLE TYPE - RATIO - DIFFERENTIAL TYPE
- 52008613 '95-96 Cherokee 35 3.73 NL
- 52009401 '94 Cherokee 35 3.73 NL
- 52037658 '91-93 Cherokee 35 3.55 NL
- 52060009 '95 Cherokee 8-1/4 4.10 L
- 52067357 '91-93 Cherokee 35 3.55 L A.B.S.
- 52067662 '91-93 Cherokee 30 3.55 NL w/o disconnect axle
- 52067663 '91-93 Cherokee & Comanche 30 4.10 NL w/o disconnect axle
- 52067664 '91-93 Cherokee & Comanche 30 3.07 NL w/o disconnect axle
- 52067690 '92-93 Cherokee 8-1/4 3.55 NL
- 52067694 '91-93 Cherokee 35 3.07 NL
- 52067695 '91-93 Cherokee 35 3.07 L
- 52067696 '91-93 Cherokee 35 3.55 L A.B.S.
- 52067697 '91-93 Cherokee 35 3.55 NL
- 52067698 '91-93 Cherokee 35 3.55 L A.B.S.
- 52067699 '91-93 Cherokee 35 3.55 NL
- 52067761 '91-93 Cherokee & Comanche 30 3.55 NL w/o disconnect axle
- 52067968 '91-93 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52068012 '91-92 Comanche 35 3.07 NL
- 52068027 '92-93 Cherokee 8-1/4 3.55 NL
- 52068047 '91-93 Cherokee & Comanche 30 3.07 NL w/o disconnect axle
- 52068048 '91-93 Cherokee & Comanche 30 4.10 NL w/o disconnect axle
- 52068051 '91-93 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52068054 '91-93 Cherokee 30 4.10 NL w/o disconnect axle, R.H.D.
- 52068070 '91-93 Cherokee 35 3.55 L
- 52068071 '91-93 Cherokee 35 3.07 L
- 52068073 '91-93 Cherokee 35 4.11 NL
- 52068074 '91-93 Cherokee 35 3.55 NL
- 52068077 '91-93 Cherokee 35 3.55 NL
- 52068078 '91-93 Cherokee 35 3.07 NL
- 52068141 '91-93 Cherokee 35 3.73 NL
- 52068264 '91-93 Cherokee 30 3.55 NL w/o disconnect axle
- 52068265 '91-95 Cherokee 35 3.55 NL
- 52068266 '91-96 Cherokee 35 3.55 L
- 52068366 '94 Cherokee 8-1/4 3.55 NL
- 52068368 '94-96 Cherokee 8-1/4 4.10 NL
- 52068421 '94-96 Cherokee 30 3.07 NL w/o disconnect axle
- 52068423 '94-96 Cherokee 30 3.55 NL w/o disconnect axle
- 52068424 '94-96 Cherokee 30 4.10 NL w/o disconnect axle
- 52068425 '94-95 Cherokee 30 3.55 NL w/o disconnect axle
- 52068517 '94-96 Cherokee 30 3.07 NL w/o disconnect axle
- 52068559 '94-96 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52068560 '94-96 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52068564 '94-96 Cherokee 30 4.10 NL w/o disconnect axle, R.H.D.
- 52068634 '91-93 Cherokee & Comanche 30 3.07 NL w/o disconnect axle
- 52068641 '91-93 Cherokee & Comanche 30 3.07 NL w/o disconnect axle
- 52068642 '91-93 Cherokee & Comanche 30 3.55 NL w/o disconnect axle
- 52068643 '91-93 Cherokee & Comanche 30 4.10 NL w/o disconnect axle
- 52068668 '94-96 Cherokee 8-1/4 3.07 NL
- 52068669 '94-96 Cherokee 8-1/4 3.07 L
- 52068670 '94-96 Cherokee 8-1/4 4.10 NL
- 52068671 '94-95 Cherokee 8-1/4 4.10 L
- 52068675 '94-96 Cherokee 35 3.55 L
- 52068679 '94-95 Cherokee 35 3.07 L
- 52068688 '94-96 Cherokee 35 4.11 L
- 52068689 '94-95 Cherokee 35 4.11 NL
- 52068700 '94-95 Cherokee 35 3.55 NL
- 52068714 '94-95 Cherokee 35 3.55 L
- 52068721 '94-95 Cherokee 35 3.55 NL
- 52068728 '94-95 Cherokee 35 3.55 NL
- 52068740 '94-96 Cherokee 35 3.07 NL
- 52068741 '94-96 Cherokee 35 3.07 NL
- 52068742 '94-95 Cherokee 35 3.07 L
- 52068743 '94-95 Cherokee 35 3.55 L
- 52068744 '94-95 Cherokee 35 3.55 NL
- 52068749 '94 Cherokee 8-1/4 3.55 NL
- 52068800 '94 Cherokee 8-1/4 3.55 L
- 52069008 '94-96 Cherokee 8-1/4 3.07 L
- 52069193 '95-97 Cherokee 30 3.07 NL w/o disconnect axle
- 52069194 '95-97 Cherokee 30 3.55 NL w/o disconnect axle
- 52069195 '95-97 Cherokee 30 4.10 NL w/o disconnect axle
- 52069196 '95-97 Cherokee 30 3.73 NL w/o disconnect axle
- 52069197 '95-97 Cherokee 30 3.55 NL w/o disconnect axle
- 52069198 '95-97 Cherokee 30 3.07 NL w/o disconnect axle
- 52069199 '95-97 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52069200 '95-97 Cherokee 30 3.55 NL w/o disconnect axle, R.H.D.
- 52069201 '95-97 Cherokee 30 4.10 NL w/o disconnect axle, R.H.D.
- 52069227 '95 Cherokee 8-1/4 3.55 NL
- 52069229 '94-95 Cherokee 8-1/4 3.07 NL
- 52069230 '94-96 Cherokee 8-1/4 3.07 L
- 52069231 '94-96 Cherokee 8-1/4 4.10 NL
- 52069232 '94-96 Cherokee 8-1/4 4.10 L
- 52069233 '95 Cherokee 8-1/4 3.55 NL
- 52069235 '94-96 Cherokee 8-1/4 4.10 NL
- 52069236 '94-96 Cherokee 8-1/4 4.10 L
- 52069600 '94-96 Cherokee 35 4.11 L
- 52069603 '95 Cherokee 8-1/4 3.55 NL
- 52069605 '95 Cherokee 8-1/4 3.55 NL
- 52069780 '94-96 Cherokee 35 3.73 NL
- 52069781 '94-96 Cherokee 35 3.73 NL
- 52069785 '94-96 Cherokee 35 3.07 L
- 52069786 '94-96 Cherokee 35 4.11 L
- 52069787 '94-96 Cherokee 35 4.11 L
- 52069799 '96 Cherokee 35 3.07 L
- 52070012 '94-96 Cherokee 30 3.55 NL w/o disconnect axle
- 52070013 '94-96 Cherokee 30 3.73 NL w/o disconnect axle
- 52070047 '94-95 Cherokee 8-1/4 3.55 L
- 52070048 '94-95 Cherokee 8-1/4 4.10 L
- 52070062 '95-96 Cherokee 8-1/4 4.10 L
- 52098930 '96 Cherokee 8-1/4 3.55 NL
- 52098931 '96 Cherokee 8-1/4 3.55 L
- 52098932 '96 Cherokee 8-1/4 4.10 NL
- 52098933 '96 Cherokee 8-1/4 3.07 NL
- 52099457 '97 Cherokee 35 3.55 L
- 52099458 '97 Cherokee 35 3.55 L
- 52099459 '97 Cherokee 35 3.07 L
- 52009460 '97 Cherokee 35 3.73 L
- 52099467 '97 Cherokee 35 3.73 NL
- 52099468 '97 Cherokee 35 3.73 L
- 52009473 '97 Cherokee 35 3.55 NL
- 52009474 '97 Cherokee 35 3.07 NL
- 53005574 '90 Cherokee, Wagoneer & Comanche 30 3.07 NL disconnect axle
- 53005575 '90 Cherokee, Wagoneer & Comanche 30 3.07 NL disconnect axle
- 53005576 ’90-93 Cherokee, Wagoneer & Comanche 30 3.55 NL disconnect axle
- 53005577 '90 Cherokee, Wagoneer & Comanche 30 4.10 NL disconnect axle
- 53005578 '90 Cherokee, Wagoneer & Comanche 30 4.10 NL disconnect axle
- 53005579 '90 Cherokee, Wagoneer & Comanche 30 4.56 NL disconnect axle
- 53005580 ’90-93 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle
- 53005581 '90-93 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle
- 53005582 '90-93 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle, A.B.S.
- 53005584 '90 Cherokee & Wagoneer 35 3.07 NL
- 53005585 '90 Cherokee & Wagoneer 35 3.55 NL
- 53005586 '90 Cherokee & Wagoneer 35 3.55 L
- 53005587 '90-93 Cherokee & Wagoneer 35 3.55 NL A.B.S.
- 53005588 '90-93 Cherokee & Wagoneer 35 3.55 L A.B.S.
- 53005589 '90 Cherokee & Wagoneer 35 3.55 NL
- 53005590 '90 Cherokee & Wagoneer 35 4.11 NL
- 53000591 '90 Cherokee & Wagoneer 35 4.11 L
- 53005592 '90 Cherokee & Wagoneer 35 4.56 NL
- 53005982 '90 Cherokee & Wagoneer 35 3.07 L
- 53008596 '90 Comanche 35 3.07 NL
- 53008597 '90 Comanche 35 3.55 NL
- 53008598 '90 Comanche 35 4.11 NL
- 53008599 '90 Comanche 35 4.56 NL
- 53008601 '91-92 Comanche 44 3.07 NL
- 53008602 '91-92 Comanche 44 3.07 L
- 53008603 '91-92 Comanche 44 3.54 NL
- 53008604 '91-92 Comanche 44 3.54 L
- 53008605 '91-92 Comanche 44 4.10 NL
- 53008657 '90 Cherokee & Wagoneer 35 4.11 L
- 53008657 '91-93 Cherokee 35 4.11 L
- 53008658 '90-93 Cherokee & Wagoneer 35 3.07 L
- 53008659 '90-93 Cherokee & Wagoneer 35 3.55 L
- 53009321 '91-93 Cherokee & Comanche 30 3.07 NL disconnect axle
- 53009322 '91.93 Cherokee 30 3.07 NL disconnect axle
- 53009323 '91.93 Cherokee & Comanche 30 3.55 NL disconnect axle
- 53009324 '91.93 Cherokee & Comanche 30 4.10 NL disconnect axle
- 53009325 '91-93 Cherokee 30 4.10 NL disconnect axle
- 53009804 '91-93 Cherokee 35 3.07 NL
- 53009805 '91-93 Cherokee 35 3.55 NL
- 53009806 '91-93 Cherokee 35 4.11 NL
- 53009808 '91-93 Cherokee 35 3.55 NL
- 53009809 '91-92 Comanche 35 3.55 NL
- 53009810 '91-92 Comanche 35 4.11 NL
- 1984 - 1990 AMC / Chrysler codes (pre Daimler-Benz)
- 8953000393 '86-87 Cherokee, Wagoneer & Comanche 30 3.54 NL disconnect axle
- 8953000394 '86-89 Cherokee, Wagoneer & Comanche 30 4.10 NL disconnect axle
- 8953000395 '84-85 Cherokee & Wagoneer 30 3.73 NL disconnect axle
- 8953000396 '84-85 Cherokee & Wagoneer 30 3.73 NL disconnect axle
- 8953000930 '86-89 Cherokee, Wagoneer & Comanche 30 3.07 NL disconnect axle
- 8953000931 '84-85 Cherokee & Wagoneer 30 3.31 NL disconnect axle
- 8953000932 '84-87 Cherokee, Wagoneer & Comanche 30 3.31 NL disconnect axle
- 8953001214 '84-85 Cherokee & Wagoneer 30 3.31 NL disconnect axle
- 8953001215 '84-85 Cherokee & Wagoneer 30 3.31 NL disconnect axle
- 8953001218 '84-85 Cherokee & Wagoneer 30 3.31 NL disconnect axle
- 8953001219 '84-85 Cherokee & Wagoneer 30 3.31 NL disconnect axle
- 8953001326 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953001327 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953001364 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953001366 '84-85 Cherokee & Wagoneer 30 3.73 NL w/o disconnect axle
- 8953002091 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953002092 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953002093 '84-85 Cherokee & Wagoneer 30 3.31 NL w/o disconnect axle
- 8953002094 '84-85 Cherokee & Wagoneer 30 3.73 NL w/o disconnect axle
- 8953003071 '87-90 Comanche 44 4.10 NL
- 8953003427 '87 Cherokee & Wagoneer 35 3.55 L
- 8953003435 '86-87 Cherokee, Wagoneer & Comanche 30 3.54 NL w/o disconnect axle
- 8953003436 '86-87 Cherokee, Wagoneer & Comanche 30 4.10 NL w/o disconnect axle
- 8953003497 '86-89 Cherokee, Wagoneer & Comanche 30 4.56 NL disconnect axle
- 8953003514 '87-89 Cherokee & Wagoneer 35 3.08 L
- 8953003516 '87-89 Cherokee & Wagoneer 35 3.08 NL
- 8953003692 '86 Cherokee & Wagoneer 35 3.54 NL
- 8953003693 '86-89 Cherokee & Wagoneer 35 4.11 L
- 8953003695 '86-89 Cherokee & Wagoneer 35 4.11 NL
- 8953003697 '86 Comanche 35 3.54 NL
- 8953003698 '86 Comanche 35 4.11 L
- 8953003699 '86 Comanche 35 4.11 NL
- 8953003700 '86-87 Comanche 44 4.10 L
- 8953003701 '86-87 Comanche 44 4.10 NL
- 8953004043 '86 Cherokee & Wagoneer 35 3.31 NL
- 8953004045 '86 Comanche 35 3.31 NL
- 8953004215 '86 Cherokee & Wagoneer 35 3.31 NL
- 8953004216 '86 Cherokee & Wagoneer 35 3.54 NL
- 8953004217 '86 Cherokee & Wagoneer 35 4.11 NL
- 8953004218 '86 Cherokee & Wagoneer 35 4.11 L
- 8953004219 '86 Comanche 35 3.31 NL
- 8953004220 '86 Comanche 35 3.54 NL
- 8953004221 '86 Comanche 35 4.11 NL
- 8953004222 '86 Comanche 35 4.11 L
- 8953004244 '86-89 Cherokee, Wagoneer & Comanche 30 4.10 NL disconnect axle
- 8953004458 '86-89 Cherokee, Wagoneer & Comanche 30 4.10 NL w/o disconnect axle
- 8953004459 '86-87 Cherokee, Wagoneer & Comanche 30 3.54 NL w/o disconnect axle
- 8953004512 '86 Cherokee & Wagoneer 35 3.31 NL
- 8953004513 '86 Cherokee & Wagoneer 35 3.54 NL
- 8953004514 '86 Cherokee & Wagoneer 35 4.11 NL
- 8953004515 '86 Cherokee & Wagoneer 35 4.11 L
- 8953004516 '86 Comanche 35 3.31 NL
- 8953004517 '86 Comanche 35 3.54 NL
- 8953004518 '86 Comanche 35 4.11 NL
- 8953004519 '86 Comanche 35 4.11 L
- 8953004680 '87-89 Cherokee & Wagoneer 35 3.55 NL
- 8953004682 '87-89 Comanche 35 3.55 NL
- 8953004683 '87 Comanche 35 3.55 L
- 8953004694 '86-90 Comanche 44 3.54 NL
- 8953004695 '86-90 Comanche 44 4.10 NL
- 8953004697 '86 Comanche 35 3.55 NL
- 8953004768 '86 Comanche 35 3.31 NL
- 8953004769 '87-89 Comanche 35 4.11 NL
- 8953004770 ‘87-89 Comanche 35 3.08 NL
- 8953004771 '87 Comanche 35 3.08 L
- 8953004772 '87-89 Cherokee & Wagoneer 35 4.56 NL
- 8953004773 '87-89 Comanche 35 4.56 NL
- 8953005001 '86-87 Cherokee & Wagoneer 44 3.07 NL
- 8953005002 '86-87 Cherokee & Wagoneer 44 3.07 L
- 8953005003 '86-87 Cherokee & Wagoneer 44 3.54 NL
- 8953005004 '86-87 Cherokee & Wagoneer 44 3.54 L
- 8953005005 '86-90 Comanche 44 3.07 NL
- 8953005006 '86-90 Comanche 44 3.07 L
- 8953005007 '86-90 Comanche 44 3.54 NL
- 8953005043 '86-89 Cherokee, Wagoneer & Comanche 30 3.55 NL disconnect axle
- 8953005045 '86-89 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle
- 8953005172 '87-89 Cherokee & Wagoneer 35 3.55 NL
- 8953005173 '87-89 Cherokee & Wagoneer 35 3.55 L
- 8953005190 '87-89 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle
- 8953005191 '86-87 Cherokee & Wagoneer 44 3.54 NL
- 8953005192 '86-87 Cherokee & Wagoneer 44 3.54 L
- 8953005193 '87-89 Cherokee & Wagoneer 35 3.55 NL
- 8953005215 '87-89 Cherokee & Wagoneer 35 3.55 NL A.B.S.
- 8953005216 '87-89 Cherokee & Wagoneer 35 3.55 L A.B.S.
- 8953005336 '87-89 Cherokee & Wagoneer 35 4.11 NL
- 8953005337 '87-89 Cherokee & Wagoneer 35 4.11 L
- 8953005338 '87-89 Cherokee & Wagoneer 35 4.56 NL
- 8953005412 '87-89 Cherokee, Wagoneer & Comanche 30 3.55 NL w/o disconnect axle
- 8953005413 '87-89 Cherokee, Wagoneer & Comanche 30 3.07 NL w/o disconnect axle
- 8953005416 '87-90 Comanche 44 3.07 L
- 8953005417 '87-90 Comanche 44 3.54 L
