Old November 16th, 2013, 20:59
travisk's Avatar
travisk travisk is offline
Adding a slight bend to an exhaust pipe
So I just added a Walker tailpipe and rear exhaust hanger to my XJ because the previous owner had cut it off.
The new pipe rubs against the shackle and the bottom of the bumper. I need to bend it out of the way by about an inch. Is there an easy way to do this?
'98 XJ, mall crawlin.
Off-Road Trails at www.dirtopia.com
Old November 16th, 2013, 22:22
bluejeepkid bluejeepkid is offline
Re: Adding a slight bend to an exhaust pipe
Smack it with a hammer lol
Old November 16th, 2013, 22:29
Mach2nh Mach2nh is offline
Trim off the end of the shackle if its not being used and it wont hit.
Old November 16th, 2013, 22:30
travisk's Avatar
Good call on trimming the shackles. They seem to attract rocks anyways.
Old November 17th, 2013, 07:44
MoFo MoFo is offline
Gone but not forgotten...
That looks like a new pipe, so hopefully it hasn't rusted itself tight to the muffler. If you loosen the clamps at both ends of the muffler, and rotate the muffler and pipes a little, you should be able to move the pipe to the side a little. While you are at it, cut about 2" off the end of the pipe. That is what will hit the rocks.
Old November 17th, 2013, 08:27
scottmcneal's Avatar
scottmcneal scottmcneal is offline
The 97 Club
If he cuts off 2" of the pipe won't that melt the bushing?
Smiley face added so people won't feel but t hurt.
Don't make old people mad.We don't like being old in the first place, so it doesn't take much to piss us off.
RIP Shady, the Greatest Father & man i will ever know.
Old November 17th, 2013, 09:09
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
just cut the pipe before the bend and add a turndown there
Old November 17th, 2013, 10:02
heyhar's Avatar
heyhar heyhar is offline
Maybe it's a bad viewing angle. but the exhaust pipe hanger doesn't appear to be properly installed. I've used Walker exhaust parts many times through the years, and never had one, especially for our XJs, that didn't fit perfectly.
Old November 17th, 2013, 12:57
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Originally Posted by heyhar View Post
......the exhaust pipe hanger doesn't appear to be properly installed......
Good eye. Might be a simple matter of loosening the
tailpipe/muffler clamp and adjusting the hanger.
Old November 17th, 2013, 13:27
travisk's Avatar
It's true that the bolt hole on the hanger doesn't line up just right, but the studs are still right in the OEM position. Everything is up against the frame attachments of the bumper, so it can't move inboard anyway.
The tailpipe just isn't perfectly compatible with the extended shackles and that big fat bumper. I can fix half of the problem by trimming the shackle.
Old November 17th, 2013, 13:30
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
I doubt it, there is room there to just do a partial trim. But then he'll NEVER be able to use that hole, I'd keep that option open and leave the shackle as is.
That's what I would do (read: that's what I did). I actually don't have a turndown per se, I just have an angle tip "resonator" (which doesn't really resonate)
It's not a stock hanger, it's a universal one. Does look wonky. You may want to physically lift the tailpipe and then tighten up the hanger at the lifted height. If the hardware doesn't fit right, get creative with some alternate hardware.
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
Old November 17th, 2013, 14:22
travisk's Avatar
Yep, got it. Added a spacer on the hanger studs and dropped the whole thing down 1/2". It clears the bumper and the shackle now.
Thanks everyone!
Old January 23rd, 2014, 08:30
travisk's Avatar
Added a ZJ gas tank skid and shackle relocation brackets. Now I'm back to square one. Doh!
Old January 23rd, 2014, 10:03
thanasi85's Avatar
thanasi85 thanasi85 is offline
Just have the exhaust tip come right off the muffler and toss the rest of the exhaust pipe that bends around your rear shock and gas tank out.. I have had this done to three of the XJs in out family with no issues.
Old January 23rd, 2014, 10:10
travisk's Avatar
That's how I melted my gas tank.
Adding Flex Tube to Down Pipe rockchucker Modified Tech Discussion 6 April 7th, 2012 15:16
need exhaust pipe wazhier Arizona For Sale/Wanted 0 January 15th, 2011 11:29
exhaust down pipe DangerousJordan Jeep Street and Performance 5 September 9th, 2008 20:50
exhaust down pipe Ben H Modified Tech Discussion 11 December 14th, 2005 07:41
Quiet Exhaust, slight increase in MPG and HP jmsull Modified Tech Discussion 40 July 31st, 2005 14:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
