Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old June 10th, 2013, 15:38
Gforce Gforce is offline
Low Oil Pressure at Idle-2000 Jeep Cherokee 4.0L
My Oil pressure gauge started acting funny first going all the way to the top then started functioning in reverse Etc. Changed sending unit and then it rarely went over 40 even at highway speeds and drops to zero at idle. Checked it out at numerous shops and eventually changed the Oil pump where it now registers normal at speeds but still drops to zero at idle. Engine is smooth and runs great at speeds-no knocking or rough idle when gauge drops to zero. Has anyone ever experienced this issue? Last mechanic was baffled and says I might have a Crank shaft issue and That I should look for a used engine. Need Help/advice.
Old June 10th, 2013, 15:48
Digger87xj's Avatar
Digger87xj Digger87xj is offline
Re: Low Oil Pressure at Idle-2000 Jeep Cherokee 4.0L
cam bearing issue is more likely.
Old June 10th, 2013, 16:47
Tim00XJ's Avatar
Tim00XJ Tim00XJ is offline
Mine had the same issue -- the oil pressure would drop to zero only at idle (sounded fine when this happened). Turned out to be a cracked head. Basically, the coolant is leaking into the oil causing it to thin out. You might want to check the head as well. Since it is a 2000, just like mine, it has the 0331 head.
Old June 10th, 2013, 16:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
First thing to do is to verify the readings on the dashboard gauge. Install a mechanical oil pressure gauge and see if it agrees with the gauge.
An engine with low oil pressure may run for many additional miles, so any discussion about engine swaps is premature until you verify the pressure and/or until it actually fails.
Originally Posted by bimmerjeeper
I spent a few hours researching how to jack up an XJ, but even this is more complex than a normal car.
Old June 10th, 2013, 20:10
Tim00XJ's Avatar
Yup, ran mine for over a year with this issue. Just had to change the oil more often.
Old June 11th, 2013, 07:29
Thanks for the replies! To be truthful although the mechanic mentioned engine swap he did say that I should have no major concerns about driving the vehicle as it is for years to come!?? He said engine runs strong and smooth which is does. Never had any power or rough running issues so will see. Will check the Cam or head to rule those out and make sure he had a mechanical gauge attached.
Old June 11th, 2013, 15:53
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
This is sure a possibility with the 00-01. Are you having to add any coolant? One of the major symptoms of a cracked 0331 cylinder head is "unexplained coolant loss".
Old June 13th, 2013, 09:46
As a matter of Fact I do have to add Coolant every week or so! Changing the Cylinder head would be a lot better than complete engine swap.
How can I tell for sure - What test can be done--Compression Test? HELP--LOL
Old June 13th, 2013, 09:57
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Only bad 4.0 block I have ever heard of had a huge visible hole in from a rod that got launched. The head is always the issue with an 0331 from all that I have read.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old June 13th, 2013, 14:13
joe_peters joe_peters is offline
1. Remove oil filler cap--with a strong light check head between cylinder 3 and 4, look for latte or coolant.
2. Check dipstick (crankcase) for latte.
3. Do a compression test on the engine.
4. Do a cylinder leak down test on no. 3.
5. Test for hydrocarbons in the cooling system.
One or more of the above will confirm the condition of your head/headgasket.
Old June 14th, 2013, 12:03
Thanks so much, I will check this out ASAP. Would that explain why last month when I got a tune-up the mechanic mentioned that one plug looked burned or fouled. Mechanic who changed the Oil pump this past week said the oil looked fine with no trace of coolant
Old June 14th, 2013, 20:36
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
..... Would that explain why last month when I got a tune-up the mechanic mentioned that one plug looked burned or fouled. Mechanic who changed the Oil pump this past week said the oil looked fine with no trace of coolant
Yes, that specific cylinder with the fouled plug is where
the crack is. Good news is that the oil looks OK.
A new head should fix it.
Old June 16th, 2013, 12:22
yossarian19's Avatar
yossarian19 yossarian19 is offline
Y'know, I'm all for saving money with intelligent repair choices but if the coolant is getting into the oil enough to thin it out, I'd at least drop the oil pan & check out the bearing conditions before I put a head on it. You might fix the leak, but it might be too late for the bottom end. Helluva thing to put a head on it & THEN find out your bottom end is shot...
Old June 16th, 2013, 13:03
MoFo MoFo is offline
Gone but not forgotten...
Antifreeze WILL destroy the bearings. It would be nice if it only took out the mains and rods, but it also eats the cam bearings. You need to pull the block to change those.
How long did you drive it with this problem. I drove my 2000 XJ with the cracked 0331 head 800 miles, returning from South Carolina. That was long enough to ruin all the bearings. It also put enough wear on the cam that I had to make a call. I chose not to replace it, but now I wish I had.
Old June 17th, 2013, 06:24
Ouch.
In most cases it will be more cost effective to put a long block with a warranty in the car than to rebuild what you've got. Stroker or 4.0 is a tough call at that point.
Unless you can assemble it in the garage and are qualified to do so, driving something else while you get the machine work done & spend 40 hours or so checking clearances...
2000 Jeep Cherokee DubbyDoo NAC Classifieds 8 January 11th, 2013 04:31
2000 Jeep Cherokee DubbyDoo SEC For Sale / Wanted Forum 0 December 10th, 2012 10:46
1997 Jeep Grand Cherokee Idle Oil Pressure (4.0 engine) jb1331 Tow Rigs, Trailers, and Other Tech Discussion 8 February 23rd, 2011 19:55
High Oil Pressure 2000 Cherokee ?? oldbill OEM Tech Discussion 8 April 7th, 2010 05:18
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
