Old May 10th, 2013, 22:03
Monster3663 Monster3663 is offline
Alternative to Rusty's intake tube for Reni or HO.
This was how I did my intake tube. It works just as good as Rusty's airtube. The whole setup was $40.00 at Autozone. Rusty's tube and filter plus shipping about $90.00
This is a 6X3 inch air tube $9.99 and a 6.5 inch filter $19.99.
Vacuum sensor tube. $9.99
Put together with a piece of metal stock. Hole drilled in 6 inch tube and bolt inserted from inside out to hold bracket. Bottom of bracket uses same bolt that holds air box down.
Can be used with or without vacuum to EGR if not renix. One hose to vent, one hose to canister and the vacuum to EGR if needed.
I got rid of vacuum mess on Renix and and ran each hose individually. I cut the end off the old vacuum adapter.
The completed project.
http://www.naxja.org/forum/images/sm...pirateflag.gif
Old May 10th, 2013, 22:20
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Re: Alternative to Rusty's intake tube for Reni or HO.
Part numbers?
Old May 10th, 2013, 22:30
6 inch tube Autozone #422444 Spectre #8718. Vacuum sensor tube AZ#422488 Spectre # 8707. Filter AZ#628426 Spectre #9132.
Old May 22nd, 2013, 08:28
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
Looks a heck of a lot better than the Rusty's setup too!
Just a note for us jerks in CA this will NOT pass CA smog inspection, but neither will the Rusty's setup so I guess that's a moot point.
Old May 31st, 2013, 06:13
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Will this same set up work for a 2001?
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old May 31st, 2013, 10:06
Should work on all years.
Old July 3rd, 2013, 18:57
Yes it will work. The only thing you will have to do is change the plastic clamp to a metal clamp. The metal one closes tighter. Here it is on a 1998 intake tube.
Rusty's intake tube mount $20 obo GrimmJeeper SoCal For Sale 3 April 8th, 2011 12:25
Rusty's Intake tube XJ4Christ Modified Tech Discussion 6 May 4th, 2010 17:22
Rusty's TJ intake tube redneck Arizona For Sale/Wanted 0 July 25th, 2007 13:33
Rusty's Intake Tube xjh3 Modified Tech Discussion 15 August 22nd, 2006 06:32
Rusty's intake tube Easyrydin2 Modified Tech Discussion 1 August 9th, 2004 23:52
