Old May 2nd, 2013, 23:13
HappyDog HappyDog is offline
Exhaust leak at muffler inlet, outlet
The 1997 Cherokee I just got has a bolt-in Magnaflow muffler. There are sooty mraks at both the inlet and outlet showing the U-clamps are not causing a prefect seal -- the leaks occur where the semicircle of the u-bolt fairs into the semicircle of the folded sheetmetal clamp. So I have 2 leaks at each clamp for a grand total of 4 leaks.
I plan to replace this muffler with one that isn't so loud and want to know how to install the new muffler so it doesn't have these same leaks. It would be real annoying to pay the money for a quiet muffler only to hear the leaks instead!
Thanks for your help.
--HappyDog
Old May 3rd, 2013, 09:10
Talyn Talyn is offline
Re: Exhaust leak at muffler inlet, outlet
Weld it in or try the band style clamps.
For a 2000 xj what size Inlet/Oulet do I need for a new flowmaster 40series muffler ruffrich26 Midwest Chapter 3 January 11th, 2013 21:14
Muffler inlet goes into cat outlet correct? 995speed Modified Tech Discussion 23 June 11th, 2012 20:06
Another Heater Core ? Inlet and Outlet? Redsnake OEM Tech Discussion 1 February 21st, 2011 12:00
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
Catalytic Converter Inlet/Outlet reson46 OEM Tech Discussion 0 December 30th, 2003 12:59
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
