Old March 17th, 2013, 14:20
hell's Avatar
hell hell is offline
No start no crank no lights no power!
Parked my 89 xj in a lot came back and it won't start lights won't come on anywhere! Just replaced the battery ecu CPs sensor and starter relay! Didn't give me any warnings to a problem and no blown fuses! Could it be relays? Got the battery tested its 100% It's stuck on the wrong side of town surrounded by crack people! ! and I think a bum slept in it last night. Please help me
Old March 17th, 2013, 14:44
scottmcneal's Avatar
scottmcneal scottmcneal is offline
The 97 Club
Re: No start no crank no lights no power!
Cables?
Smiley face added so people won't feel but t hurt.
Don't make old people mad.We don't like being old in the first place, so it doesn't take much to piss us off.
RIP Shady, the Greatest Father & man i will ever know.
Old March 17th, 2013, 15:20
hell's Avatar
I jumped the starter terminals with a screw driver and it turns over but no start
Old March 17th, 2013, 19:25
cruiser54's Avatar
cruiser54 cruiser54 is offline
Cables?
Old March 17th, 2013, 19:56
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Ignition switch, not the key-lock mechanism, but the electrical one way under the dash on the top of the steering column may be bad.
Is it auto or manual trans?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 17th, 2013, 20:04
sam24th sam24th is offline
I had a similar issue awhile back. Turned out to be one of the fusible links on the power distribution block on the passenger side side wheel well.
Old March 17th, 2013, 20:09
joe_peters joe_peters is offline
No lights--PDC, ie the STARTER RELAY.
Cranks when jumped at the starter, but not from the key--PDC, ie the STARTER RELAY.
Check the STARTER RELAY next to the battery.
Old March 17th, 2013, 20:41
Ecomike's Avatar
NAXJA# 2091
He already replaced the starter relay, read post #1
Old March 17th, 2013, 20:52
my2monkeys my2monkeys is offline
Did you replace all that stuff after the no start or before?
Maybe the ECU connectors came loose or you got a bad starter relay.
The Green fusible links going to the starter relay will go bad.
They're the ones that go from a Red wire to the Green for the last few inches before the relay.
Old March 17th, 2013, 21:16
DOOH!
Back to reading comprehension 101.
Old March 18th, 2013, 08:43
The 97 Club
Originally Posted by scottmcneal View Post
Cables?
Originally Posted by cruiser54 View Post
Cables?
Yes i was thinking battery cables.Sorry i was thinking it and didn't write it out.
Mike could be on to it, i would look there next and make sure it is plugged in.
Crank, no start on a '96 XJ. 88magnum OEM Tech Discussion 6 January 23rd, 2013 21:54
Crank but No Start CherokeeManatee OEM Tech Discussion 11 May 29th, 2012 20:49
No crank, no radio, no lights, no nothing Arokcrwlr OEM Tech Discussion 7 June 20th, 2006 19:24
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 18:33
No-start/No-crank on 89 XJ LiveWire Jeeper OEM Tech Discussion 9 July 29th, 2004 19:19
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
