Old March 10th, 2013, 08:46
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
H.D. Offroad no lift shackle relocation install
First off this is an install thread, I will not talk price or delivery in this thread, please see the vendor forum for that info.
First begin by removing shackle bolt and lower suspension so you have enough room to work. Then cut around all corners of the OEM shackle box.
Put H.D. Relocation box in place and mark through holes for the inside mounting plate and drill the holes.
Install H.D. relocation box and supplied hardware (does not include nutstrips), comes with a 1/4" spacer place so kit can be mounted against frame or below a hitch.
Interior mounting plate also functions as a cage tie in mount.
Use supplied bolt and nut and reinstall shackle in desired location.
As you can see there is clearance for stock shackles.
By using the lower holes you not only recieve a better angle but DO NOT lose lift by just moving the shackle forward.
H.D. Offroad Engineering LLC
Now Selling Barnes4wd, let me quote your next fab project
Old March 10th, 2013, 09:20
Wiser's Avatar
Wiser Wiser is offline
Re: H.D. Offroad no lift shackle relocation install
Was this install done on a 97+ XJ?
1998 XJ
1 ton Tube Buggy
2010 Ford F-150
1978 Dodge Commander Class A
Old March 10th, 2013, 09:33
BRIANHO13's Avatar
<- Yum Chocolate
YES
Old March 10th, 2013, 12:53
OutkastBoss's Avatar
OutkastBoss OutkastBoss is offline
Well Shit I Didnt want any lift and run Stock shackles , and just bought the other ones at WF
Old March 10th, 2013, 23:00
PahlMc PahlMc is offline
So do just the three bolts connected to the nut strip hold this in place? I went with your original ones because I don't like how much side load "no lift" relocaters will see.
Any concerns with high speed jeeps?
Old March 11th, 2013, 04:30
BRIANHO13's Avatar
<- Yum Chocolate
It also bolts through the floor and to the original shackle bolt hole. With the ability to now tie these into the cage, they would probably be stronger in the long run.
Old March 11th, 2013, 17:35
stumpXJ stumpXJ is offline
NICE. The perfect solution....
Old March 11th, 2013, 18:21
sunburned sunburned is offline
Full jeep pics?
Old March 11th, 2013, 18:23
Very cool. I actually like he lift I got and the option to go back to stock. But very cool!
Old March 12th, 2013, 14:09
Red91Laredo's Avatar
Red91Laredo Red91Laredo is offline
Looks like there is a lot of adjustment available with these... is it possible to use the lower bolt holes and still get a little lift out of them, or will there be no increase in lift with this design no matter which holes are used?
I was already planning on buying your existing shackle relocators... a little lift might not be a bad thing since I want to rework my spring pack to soften it up a bit ... but if these give me both options (lift or no lift) I would go with these.
it would be cool to see a pic of how they look installed on a Jeep so we could get an idea of where everything sits. I think these may actually clear my exhaust which would be another nice thing vs. the previous design.
Old March 12th, 2013, 15:39
BRIANHO13's Avatar
<- Yum Chocolate
The hole I have that shackle in is about 35 degrees for a stock shackle. So if you use a longer than stock shackle and use that hole you might end up with a hair of lift.
Also the brackets will come with 2 extra spacers instead of 1 so you could drop the entire assembly 1/2".....
Pics on a rig coming soon.
Old March 19th, 2013, 17:42
BRIANHO13's Avatar
<- Yum Chocolate
FULL SET PIC
Old March 19th, 2013, 19:34
VAhasnoWAVES VAhasnoWAVES is offline
mmmmmm, bacon.
Old March 19th, 2013, 19:41
kmanxj5050 kmanxj5050 is offline
Awesome! Nice job Brian.
Old March 19th, 2013, 19:49
WTF_LOL WTF_LOL is offline
Saw my order shipped! That's fast enough that the relocation bacon might still be warm!
HD OFFROAD SHACKLE RELOCATION KIT poomero Sierra Chapter For Sale 3 March 21st, 2011 09:50
HD Offroad Rocks!!! (Shackle Relocation) XJRN Modified Tech Discussion 4 November 22nd, 2010 11:11
HD Offroad Engineering Shackle Relocation ChattTacoma05 SEC For Sale / Wanted Forum 4 July 15th, 2010 10:53
H.D. Offroad Engineering Shackle Relocation Kit Achmed South East Chapter 8 October 21st, 2009 18:50
H.D. Offroad Engineering Shackle Relocation Kit Achmed Modified Tech Discussion 10 April 11th, 2009 11:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
