Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old February 21st, 2013, 22:17
freerider15's Avatar
freerider15 freerider15 is offline
How To: Build A Cheap Rollover Catch Can / Breather
*This is also in Mod-Tech, but I know some don't get over there too often*
Alright, so I cannot remotely take credit for this. I got the idea from a thread on Pirate:
http://www.pirate4x4.com/forum/gener...nder-15-a.html
But, since I know most of you don't venture there...I'll go ahead and post the build up of mine now
So a list of what you'll need (minumum):
* Aluminum Water bottle - Free in my case thanks to CSU
* Breather Filter - $6.32 + tax after 40% off at Advance Auto
* PCV Valve (PN# PCV1122) - $2.99 + tax at AutoZone
* 3/4" x 1/2" Hex Bushing - $1.95 + tax at Home Depot
* 3/8" ID x 1/2" MIP Brass Hose Barb Adapter - $3.12 + tax at Home Depot
So, total for the main stuff (if you have bottles free like I did):
$14.38
So on to the "build":
An overall picture of everything:
So I did think slightly differently than the write-up on pirate, not by much though. You can either go the route in the pirate thread, or follow mine.
First things first. I smoothed out the small nipple lip on the PCV valve, then tapped it to 3/8x16.
*Note...the smaller part of the PCV valve measures out to about .350 so not completely .375 but taps just fine...you'll see where this makes a difference in a few. As well...the PCV valve is a one way valve so the internal "ball" will prevent it from leaking out in case of a rollover.
After it has been tapped:
Now...drill a hole in the center of the bottom of the bottle. Since the piece isn't really 3/8", I used a size T(~.358") drill bit for a better, tighter fit.
From here, I assembled like so with washers and o-rings for sealing. You can do as you like...this is just what I did.
Now...it isn't the easist to get done inside the bottle but I figured out my own little tricks and it goes pretty quick.
Next, assemble the two adapters together and screw into the neck of the bottle. I used RTV between all threads, but you can use whatever you feel like...RTV, JB Weld. Whatever makes ya feel better
Last but not least...put the filter over the piece of the PCV valve sticking out and viola...done!
OK...so a few more side notes. The filters I got didn't like to go on real easy. So to get them on I had to use a heat gun to get the rubber maleable then push it on. In order to get it more "flush" as shown below...I had to drill the rubber out to a larger hole (~1/2"), then heat and push. But, once done it comes out a little nicer like so:
I'll get them mounted soon and add some pictures!
XJ Buggy On Tons
Old February 22nd, 2013, 08:15
Gotlift01 Gotlift01 is offline
Re: How To: Build A Cheap Rollover Catch Can / Breather
I've made a couple identical to that before.....found the same thread on Pirate awhile back. They work awesome and I think they look pretty damn cool.
Old February 22nd, 2013, 08:26
Yeah, they definitely work pretty dang good. I poured water in in and the PCV valve would baaaaarely start to drip out water.
So I think it is safe to say heavier viscosity fluids will be no problem
I actually went and looked at the dollar store (Dollar Tree) since it sounds like they carried them.
But I wasn't able to find any locally for "cheap"....i.e. dollar store.
Hell...next time I go to a CSU game and they hand these out....i'm gonna hoard a crapload of them
XJ Buggy On Tons
Old February 22nd, 2013, 08:29
That's where I bought the ones I used was at the dollar store. They had a huge bin full of them in like 10 different colors.
I used to never really care for them for water bottles, but after I found the thread and made a few of them, every time I get a chance to snag one I do!
Old February 22nd, 2013, 10:51
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
Nice! This looks like just the thing I need for the flipped D300 going into the buggy. These flipped 300's always seem to puke gear oil out of the breather hose. If I mounted something like this to a tube on the cage above the case, this should keep oil from leaving the breather system...... yes?
Failure is not an option...... it comes standard with every Ford.
End of Watch: MC1, 1312 & 0369....... Rest easy brothers, we've got it from here. -----
Old February 22nd, 2013, 13:09
Hell yeah...if I had seen any of these in the dollar store I would have gotten several!
Troy, I'll be running one of these each for my doubler, front, and rear axle and yep...it'll keep oil from puking out since you have both a resevoir AND a one way valve.
XJ Buggy On Tons
Old February 22nd, 2013, 16:11
YELLAHEEP's Avatar
Why would ya need to run the PCV? Wouldn't it be better to allow the blow by to run back down into the gear box when it's sitting?
Old February 22nd, 2013, 16:46
xj-grin's Avatar
xj-grin xj-grin is offline
NAXJA Member #1096
I was thinking the same thing -- if its gravity back to the case when upright, why the PCV?
As the reasons for the carnage eat their meat and lick the gravy, we oil the jaws of the war machine and feed it with our babies - As the madmen play on words and make us all dance to their song, to the tune of starving millions to make a better kind of gun. ~ BD
Old February 22nd, 2013, 22:29
One way valve...
I.E...
Its open and "breathes" when your upright...but closes if your on your lid (like a ball & socket valve)
XJ Buggy On Tons
Old February 22nd, 2013, 22:58
YELLAHEEP's Avatar
For some reason I thought the valve was at the bottom....... Carry on.....
Old February 22nd, 2013, 23:07
xj-grin's Avatar
NAXJA Member #1096
^^ what he said.
Old February 28th, 2013, 13:03
So...since these are easy and cheap to build.
Imma give anyone I see at COFest some schit if I see a damn soda bottle with hose stuck in it!
XJ Buggy On Tons
Rate This Thread:
Cheap Speed Build Curser JeepSpeed, Prerunner and Competition Tech Forum 8 April 26th, 2010 21:35
Cheap build help... over2land SoCal Chapter 0 April 12th, 2010 23:39
Another Cheap XJ Winch bumper build desertfox1023 Modified Tech Discussion 10 August 17th, 2009 15:52
Cheap Cherokee Build coastie124 Modified Tech Discussion 36 May 30th, 2008 18:37
cheap build up question fatkidoutdoors Modified Tech Discussion 18 July 21st, 2004 10:01
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
