Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Insert lockder question.
New at this.
If i take out my axle carrier in my dana 30 and install a Spartan insert locker do i need to rear set the backlash when i install the carrier? I already have a Detroit Ez insert locker inside that has failed... so i am just swapping out the locker for a new one. This will be my first time messing with the gears. Also is there any tips you guys have when doing this? Thanks, Brandon
![]() ...And remember to TREADLightly! ![]() |
#2
Re: Insert lockder question.
No, Not to say its still in spec though. You will have to pull the ring gear off to get the cross pin out and in. Use grease to hold the springs in during assembly and its recommnded to use a new roll pin.
#3
Why even pull the carrier?
#4
Because the ring gear has to come off. And its much easier to work with on a bench.
#5
There are great step by step videos on YouTube. Remember to use the supplied new cross pin and do not reuse the factory cross pin.
Good luck. Mine took less then 4 hours
ZJ, Atlas 4 speed MJ, 4.0HO Shortbed |
#6
You mean roll pin right?
#7
No, cross pin The large 3/4" thick 5" long pin. The spartan comes with a new hardened cross pin, the factory one is not hardened. And I've seen them break well before the carrier
#8
Ah, lockrights and aussies dont come with new ones. no problems yet.....
#9
My Aussie fit right in, cross pin came in and out just fine, if it doesn't clear just grind a tiny bit of the tooth away. Been done many a time with no ill effects, seems like loosening more bolts means more places to mess up your torque specs and cause other issues... just sayin
#10
But on a Dana 30 you have to pull the ring gear or grind teeth I guesss. If you are going to grind them, you don't want to do it with the carrier installed.... I think I would rather tourqe bolts then grind away teeth espciallly on a tiny dana 30 ring gear. ![]() Last edited by whitexj98; November 20th, 2012 at 12:14. |
#11
Just stuff a rag in the carrier and clean it up after, you'd want to anyway to inspect it while you have it apart. But to each his own, like I said before.... its just another option if he is worried about pulling it all apart. That's all |
#13
Good stuff thanks guys.
I have heard you can do it while the carrier is still installed but if you have a lower than stock gear ration you will need to remove the ring and carrier. I do have a new cross pin with the locker. But will i need a new roll pin?
![]() ...And remember to TREADLightly! ![]() Last edited by Brandon77; November 20th, 2012 at 12:52. |
#14
#15
I did a D30 lunchbox locker in a campground. Didn't pull the carrier with 3.73 gears, so the same carrier as your 4.10s.
Getting the roll pin out to release the cross shaft is the biggest PITA. Personally, I wouldn't pull the carrier unless your confident you'll get the bearing caps installed correctly. I've done it both ways and I'd rather not pull a carrier if I don't have to.
RIP Ugly Truck ![]() |
Thread Tools | |
Display Modes | |
GoFerIt otk insert? | MelloYello | Colorado Chapter | 11 | June 15th, 2011 16:45 |
Grill insert | Droopy76 | Paint and Bodywork forum | 8 | August 3rd, 2010 14:58 |
tie rod insert | homebrew | SoCal For Sale | 2 | October 10th, 2008 14:22 |
pic insert text | no_gamecocks | TEST Forum | 0 | January 14th, 2007 09:08 |
Hitch insert | RichP | Non-Tech / Off Topic | 3 | November 2nd, 2004 13:57 |
