Old September 11th, 2012, 21:57
streetxj's Avatar
streetxj streetxj is offline
Best Thermostat brand for 96' Jeep Cherokee 4.0?
I've already received the mopar TPS from wermopar.com (huge difference in quality compared to the POS cheap duralast..), now the next thing to tackle is the thermostat. Should I go with the stant superstat 180 degree thermostat or get a mopar 195 degree thermostat from the same site I ordered my TPS?
I live in south florida where it is hot and humid most of the year, so I'm thinking that a 180 degree thermostat would be better for me.
Old September 11th, 2012, 22:40
amorth's Avatar
amorth amorth is offline
Re: Best Thermostat brand for 96' Jeep Cherokee 4.0?
I've read that alot of people run with the 180 theromstat and love them. But I've also read that you should stay with the stock temp rating thermostat. I can't remember exactly why that is, but I recall it being a really good reason and that's what I'm going to do.
Old September 12th, 2012, 00:50
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Originally Posted by amorth View Post
I've read that a lot of people run with the 180 theromstat and love them. But I've also read that you should stay with the stock temp rating thermostat. I can't remember exactly why that is, but I recall it being a really good reason and that's what I'm going to do.
The computer is programed for the 195 degree thermostat. A 180 degree thermostat doesn't increase the engine's cooling capacity, it just opens earlier, causing the computer to 'think' the engine has not fully warmed up.
Try a STANT Part # 45359, 195 Degree Superstat. I get them at Rock Auto.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old September 12th, 2012, 01:43
robsjeepxj robsjeepxj is offline
Like was said it does really make a difference, the engine will still run at the same temp. I've run both, I've had the 180 for awhile now. If you want it to run cooler get an aluminum radiator or a heavier duty rated fan clutch, running LeBaron hood vents help a bit too at low speeds like when wheeling in the rocks in 4Lo.
Old September 12th, 2012, 01:46
Oh I almost forgot if you want a high quality thermostat look into Robert Shaw stats. They flow a little better too.
Old September 12th, 2012, 06:23
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
I buy plenty of aftermarket parts, but the thermostat is one thing I buy ONLY from Jeep. And they're only a buck or two higher than the others.
Never had a failure with a Mopar stat in 38 years of wrenching. I can't say that about other brands though, including Stant.
195 degrees is the correct choice for the stat for the vast majority of 4.0 engines.
Old September 12th, 2012, 07:31
cruiser54's Avatar
cruiser54 cruiser54 is offline
I've had to change out 3 Stant Superstats in the last year. Only Mopar 83501426 for me anymore. Took forever to warm up on cold days with those Stants.
Old September 12th, 2012, 14:23
Planetcat Planetcat is offline
Mopar or Robert Shaw at 195*.
Old September 12th, 2012, 17:21
streetxj's Avatar
Thanks for your help guys. I appreciate it. ^
Old September 13th, 2012, 07:26
O-Gauge Steamer O-Gauge Steamer is offline
One thing to keep in mind is that there needs to be an air bleed in the T-Stat. If the one you purchase does not come with one, one can be made simply by drilling a small (1/8" or less) hole in the T-Stat. Install the T-Stat with the air bleed at the top so it can function properly.
T-Stats from the factory come with the air bleed built in. Most, is not all, aftermarket ones do not.
Old September 13th, 2012, 12:58
VAhasnoWAVES VAhasnoWAVES is offline
assuming your cooling system is in proper working order, there is no reason not to use a 195* thermostat.
ive replaced a few stants myself, faulty right out of the box.
Best TPS sensor brand for 1996 Jeep Cherokee 4.0? streetxj OEM Tech Discussion 9 September 6th, 2012 08:03
Jeep stock thermostat housing 2000 4.0L HO tcharon For Sale: Private Party Only. XJ ITEMS ONLY 2 August 23rd, 2009 20:20
Jeep stock thermostat housing 2000 4.0L HO tcharon Arizona For Sale/Wanted 1 May 31st, 2009 09:42
Engine 4.0 Cherokee 1992 - thermostat pszczepan OEM Tech Discussion 5 March 16th, 2007 17:47
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
