Old September 3rd, 2012, 11:12
DrMoab's Avatar
DrMoab DrMoab is offline
WJ Knuckles with 1 Ton TRE's
Question for all the Guru's.
So I'm getting ready to install the knuckles, brakes and such from a WJ and I've heard you either need to run the stock WJ tie rod ends or go with some offset ones like these...
http://www.ruffstuffspecialties.com/catalog/TREOFF.html
I'd really like to run the 1 ton stuff with the holes tapered from the top to get the tie rod over the knuckle but I'm looking at the space I have between the bottom ear for the tie rod and the upper link for the drag link and I'm wondering if I will run into any interference.
Has anyone done this and have they ran into issues?
If I can get away with not running the WJ TRE's I'd be a happy guy because I can't find anyone with 24mm taps and I don't want to pay JKS's stupid price for their tie rods and drag links.
Old September 3rd, 2012, 12:17
2000bluexj 2000bluexj is offline
Re: WJ Knuckles with 1 Ton TRE's
You have to flip both the draglink and tie rod. There is not enough room to flip both. You will also need to relocate your tracbar as the angles will most likely not even be close.
Old September 3rd, 2012, 12:42
DrMoab's Avatar
I know about the track bar. I'm only asking about the tie rod ends. Your post confuses me. You say I need to flip both then you say there isn't room.
Could you clarify a little?
Old September 3rd, 2012, 12:48
Burton58's Avatar
Burton58 Burton58 is offline
i run exactly those ends on my WJ swap and they work wonderfully OTK. the only issue is that they will interfere with my 15x8" wheels even being 4"bs. 1" wheel spacers all around solved that and have some room to spare
you can see the space between the wheel and TRE here
here's the draglink and tie rod. a regular 1 ton TRE on the drag link with the offset ends on the tie rod
Old September 3rd, 2012, 13:15
DrMoab's Avatar
Awesome. Thank you. I'm looking on my phone and it's a little dark but both ends on the pass knuckle are over the knuckle and you didn't run into interference issues?
Also what track bar bracket did you use? The angles look pretty close.
philagony94xj's Avatar
philagony94xj philagony94xj is offline
I've seen a thread on one of the forums I frequent. They used Ruffstuff offset TRE and went over the knuckle. I'll see if I can dig it up later on when I get to my home PC. I know exactly what your after.
Old September 3rd, 2012, 13:28
Actually I found it rather fast. This is a good write-up.
http://naxja.org/forum/showthread.ph...=steering+swap
Hope it clears a few Q's up.
Vanimal's Avatar
Vanimal Vanimal is offline
i have that same setup as well. you will have to flip both the tie rod and drag link. you will also have rim clearance issues as mentioned, if you're running 15's. i have 3.25" backspacing on my rims and i still had to grind a little off the tie rod ends to clear the rim, but it works fine now.
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old September 3rd, 2012, 13:52
DrMoab's Avatar
17 inch wheels. Should be good there. Thanks.
Old September 3rd, 2012, 14:59
Burton58's Avatar
correct, both OTK and no interference issues. the track bar bracket and entire steering for that matter is ruffstuff. you'll be all good with the 17's too
Old September 3rd, 2012, 15:09
Vanimal's Avatar
how does it work with the non offset tre on the drag link's axle end? i went with the offset one since my axle is pushed forward a bit and i have a d44 so the cover's a bit bigger.
Old September 3rd, 2012, 18:18
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
I used Tera offset TRE's and Goferit weld-in inserts OTK and they clear the wheels (16" Moabs w 1.25" billet spacers) just fine. I have measurements and pics on my build thread. Ryan, swing by and check out my setup if you want.
Speak the Truth-Question with Boldness-Speak without fear.
Old September 3rd, 2012, 18:39
DrMoab's Avatar
Next evening I have off I'll swing by and bring your tool back.
Old September 3rd, 2012, 18:51
Vanimal's Avatar
you'll really like the setup, especially the brakes. friday night i had to stop fast to avoid hitting a cat and i was suprised how fast the thing stopped.
the one thing i do not like about it is the lack of adjustable steering stops. you may want to tap and drill some holes to put your own in like on the xj knuckles.
Old September 3rd, 2012, 18:55
DrMoab's Avatar
Can't believe you tried to avoid hitting a cat
newer style knuckles on xj d30 which previously had 2 piece knuckles? Vanimal Modified Tech Discussion 7 May 7th, 2012 13:53
Feeler: stock knuckles and WJ knuckles 2000bluexj NAC Classifieds 9 August 21st, 2010 21:55
WJ knuckles POLAR_JEEP_04 MWC For Sale/Wanted Forum 0 October 1st, 2009 18:25
WJ Knuckles!!! Dundy Modified Tech Discussion 8 February 8th, 2008 08:19
