Old August 2nd, 2012, 19:41
AZjeepin1 AZjeepin1 is offline
Writeup: 4.0 Coolant Filter Install addendum
Now, I know that dieselenthusiast has put one of these together, but I wanted to add to his brilliant idea. After all, it was his writeup that helped me do mine. His original link is here- http://www.naxja.org/forum/showthread.php?t=1085546&highlight=coolant+filter+ install
What I found lacking in the previous writeup is a SOLID, no BS parts list (complete with part numbers and costs) and pictures of the assembly prior to install. In my trips to the local stores (NAPA and Ace Hardware) this is the list of parts you will need to put together a coolant filter setup from dieselenthusiast:
1. NAPA/Wix coolant filter spin-on conversion kit (P/N 4019) $55.69
- This kit comes complete with the filter base, 3 mounting bolts, 3 washers, 3 lock washers, 3 nuts, 2 3/8'' steel elbows (only one of which will be used) and a tube of loc-tite
2. NAPA Gold coolant filter (P/N 4071) $17.99
3. (1) 3/8'' hex nipple (Lasco P/N 17-8631 112D) $3.29
4. (1) 3/8'' MIP x 3/8'' MIP brass elbow (Lasco P/N 17-8831 116D) $9.79
5. (1) 3/8'' MIP x 5/8'' brass barb air fitting (Lasco P/N 17-7737 119DG) $5.79
6. (2) 3/8'' inline ball shutoff valves $8.99ea
7. Extra heater hose. The length of this will vary from owner to owner, depending on mounting location.
8. (2) Hose clamps $0.20
Total cost (without extra heater hose and tax)- $110.73
You'll note that the parts list numbers correspond to the red numbers in the pictures.
I hope this helps clear up any gaps in his writeup! Mods, feel free to merge this with the original if need-be.
Old August 4th, 2012, 09:13
GregGA's Avatar
GregGA GregGA is offline
87 Laredo Galloping Ghost
Re: Writeup: 4.0 Coolant Filter Install addendum
Excellent write up, thank you. I plan on doing this.
You can get the filter adapter at www.fleetfilter.com for $28.94 and the filter
at the same place for $9.84.
Old August 5th, 2012, 18:34
^Nice find!!!
Old August 7th, 2012, 10:21
GregGA's Avatar
Thanks. I just found a Donaldson head for $13.25. It says it fits all Donaldson filters,
and I don't know why it wouldn't work with Baldwin/Wix
:http://filterspro.com/detail.cfm?part=1656826
Old August 7th, 2012, 15:10
That price is pretty stellar. Not sure how it'd fit where dieselenthusiast and myself have ours mounted though. The space in there is kind of limited.
Old August 7th, 2012, 20:42
GregGA's Avatar
It won't work. The filter would hit the sway bar. I'll use the wix mount.
Old November 10th, 2012, 11:36
bluejeepkid bluejeepkid is offline
Obviously the ball valves are to turn the assembly on and off when Changing the filter?
Old November 10th, 2012, 16:26
Yeah, that way you don't have coolant spilling everywhere.
Old November 10th, 2012, 17:09
Cool. Doin this mod for sure!
Old November 10th, 2012, 23:21
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Hose pinch clamps could be a good option so valves aren't required. I use them when changing tstats, or other cooling system related servicing. Thanks for the parts list,
Old November 11th, 2012, 21:50
dieselenthusiast dieselenthusiast is offline
Good job AZjeepin1!
Old November 12th, 2012, 05:54
Only running with what you started brotha!
Old November 16th, 2012, 12:48
OxInYourBox OxInYourBox is offline
Damn-another parts store trip is in order. Sweet write ups by both.
Old November 16th, 2012, 17:23
Can we get some under hood pics of the routing of the (I'm assuming) heater core lines?
Please!
Old November 16th, 2012, 20:16
Sure! I'll edit my original post to include them
Coolant Filter install - 2000 XJ dieselenthusiast Modified Tech Discussion 80 October 31st, 2017 07:54
Coolant Filter Install - By Dieselenthusiast WB9YZU Frequently Asked Questions and Writeups 1 November 12th, 2012 09:40
Lift install writeup btfury Modified Tech Discussion 4 December 13th, 2007 19:06
is there an aussie D44 install writeup? philip_g Modified Tech Discussion 4 July 15th, 2007 15:09
