Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old June 25th, 2012, 13:50
RMSinc RMSinc is offline
Precision Fuel Pumps- Good or Bad???
need a new fuel pump assembly this afternoon and cant find a bosch unit close, plus i really dont wanna spend that much as the jeeps on its way to parts. i know not to go to airtex, but is precision any good???
Old June 25th, 2012, 16:27
seanyb505's Avatar
seanyb505 seanyb505 is offline
Re: Precision Fuel Pumps- Good or Bad???
Do you need the part right now? There is a seller on ebay (fuelpumpking I believe) selling Bosch units at a decent price. No experience with the other brands.
Old July 11th, 2012, 11:56
Glyphic Glyphic is offline
I bought a Bosch and I seem to have an issue where it doesnt seem to reach as far down into the tank as my old unit. Causes the jeep to cut out when the gas swishes around when approaching 1/4 tank, dunno if it is just me.
Old July 11th, 2012, 12:35
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Are you using a 95- assembly Glyphic?
You can adjust the height of the fuel pump...
Old July 14th, 2012, 20:27
it's a 92, I don't recall seeing anything to allow that, it was a major pain to get it to seal correctly too, ended up having to drop the tank.
Old July 20th, 2012, 07:09
BIGSLVRXJ's Avatar
BIGSLVRXJ BIGSLVRXJ is offline
I imagine you're dealing with O'Reillys? I work for O'Reillys, we just started carrying Precision pumps about a month ago. I haven't heard any complaints on them yet, but I would be leary as they use Airtex part numbers. I would venture a guess that they are just relabeled Airtexs, atleast the first few batches. I like Bosch or Carter personally, Delphis are also supposed to be good. I would avoid Precision for now, just my .02.
-Collin
1990 XJ Pioneer-5.3 swap in progress-Original "BIGSLVRXJ"
1997 XJ Country-4.0, AW4, NP231, D30, C8.25, 4.5" RE Lift, 32" KM2s "BUMBLEBEE"
-Collin
Rate This Thread:
Carter Fuel pumps - anyone have a GOOD result? fuzzydog OEM Tech Discussion 8 September 27th, 2010 06:32
TBI/MPI fuel pumps impetus-93xj OEM Tech Discussion 2 January 22nd, 2008 08:11
Fuel pumps, TPI vs MPI vs? JnJ OEM Tech Discussion 8 March 18th, 2005 17:47
98+ fuel pumps RichP OEM Tech Discussion 2 August 2nd, 2004 20:13
98 xj fuel pumps BurtonUT OEM Tech Discussion 1 July 7th, 2004 14:28
