Old June 20th, 2012, 15:33
XJRocket XJRocket is offline
Build Thread! Project : Don't know yet.
So I am starting a build here. Long story short, my beloved 94 country was stolen by assholes. My brother gave me his lightly wrecked 98 base model, and I am using what little insurance money I got to build me another xj!
It's a 98, ex gov't, 4.0/AW4/231 base model with A/C, 118k. Slid into a sidewalk going way to fast. Turns over, won't start.
The Plan:
I like to think outside the box and build stuff my own way. I will be flamed much, but I have broad shoulders.
It will be driven on the street 90% of the time. It will ride good and have many creature comforts. It will look boss. It will sound good. It will be an appropriate vehicle for general ass kicking. And yes, it will actually see dirt. I promise.
It is gonna get a 4.5 longarm, cutout flares and 35s.
It needs all new running gear. Both axles are trashed. The rear will be a 9 inch with discs.
The front will be WJ derived.
The bolt pattern shall be 5 on 127 so that I may use the wide variety of wheels for JKs.
Modified Warrior Products front and rear bumpers
Contemplating some JCR bits.
The good:
The Bad:
The Ugly:
First I had the frame checked out by a body shop.
Second, I narrowed the no start condition down to no fuel coming out of the tank. I could hear the pump running but no fuel came out. So I pulled the tank and found this.
He hit so hard the fuel pump assembly sheared off and was laying in the bottom of the tank. Put a new assy in and voila, it runs like a swiss watch. Minus the hole in the exhaust from the front diff impact that made it sound like it was farting. After I got it running, I found out that the D35 rear is taco'd as well.
Old June 20th, 2012, 16:44
Re: Build Thread! Project : Don't know yet.
Think I decided on a rear axle. It's a Ford 9 3/8 out of a 76 thunderbird. It is 62" WMS-WMS, 31 spline and has discs. It is also 5 x 5 pattern, so it will match JK pattern exactly! The 9 3/8 is a modified 9", and will take a standard 9" chunk. Picked up anodular one of those for fifty bucks!! woot!
Old June 20th, 2012, 20:05
Built2Flex Built2Flex is offline
Always good to have a plan. This one doesn't seem to ambitious. Get it to where you like it first try and save thousands on rebuilding. This is what I should have done.
I'll be following this.
Old June 20th, 2012, 20:13
XJLI XJLI is offline
so, WJ30/9" axles? why not try and find a JK44 (or JK30 even) for the BP and get the track width to even up. you want the front to be a bit wider than the rear, JK axles are something like 64" WMS.
Old June 21st, 2012, 01:20
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Aren't WJ/JKaxles similar width?
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 21st, 2012, 05:58
JK is a little wider.
Old June 21st, 2012, 09:40
clean4drxj's Avatar
clean4drxj clean4drxj is offline
this and the JK 30 has a slightly larger R&P than a regular HP30.
Old June 21st, 2012, 14:49
From everything I have seen:
XJ = 60.5"
WJ = 63"
JK = 65"
I realize this plan sounds crazy but here it goes. First I am gonna put a standard XJ housing in the front to get it going. If it sits on jack stands, it will never get finished. I know me.
I will put spacers on the xj axle to adapt to the JK pattern and it will end up right at 63". That will get me going and allow me to futz with the real axle and take measurements in the real world. If the 65" width works with the bushwackers well, I will go that route (This is mostly a street driven rig, remember. And I hate tickets...).
If not, I have a crazy idea that involves cutting a WJ 2wd axle into two pieces, welding in a 9" centersection, running custom Dutchman inner axles (they are 8mins from my house) and XJ outer stubs. Either that or I could just run RCVs. Either way, I would get really any width I want, plenty of strength for a XJ, WJ brakes, crossover steering, stronger and off the shelf steering components from a WJ, perfect steering geometry/pinion angle, and a conversation starter I can be proud of.
Old June 21st, 2012, 17:27
Tacedaddy's Avatar
Tacedaddy Tacedaddy is offline
prolly still isnt gonna run too well with the number 1 O2 sensor ripped off.. the front axle looks ok from the pictures you posted, have you pulled the cover off and taken a peek inside or checked it for true?
Old June 21st, 2012, 18:14
When you see it in person, there is a distinct kink right at the pumpkin. In the one pic you can see the additional negative camber from it. That O2 sensor will be reinstalled, I am just trying to figure out what in. Anyone know of a header that replaces this part of the exhaust? I think a pacesetter goes all the way to the cat but I heard that they suck.
Old June 21st, 2012, 19:11
WrenchMonkey's Avatar
WrenchMonkey WrenchMonkey is offline
NAXJA Member #771
Originally Posted by Built2Flex View Post
Always good to have a plan. This one doesn't seem to ambitious...
Originally Posted by XJRocket View Post
...I have a crazy idea that involves cutting a WJ 2wd axle into two pieces, welding in a 9" centersection, running custom Dutchman inner axles (they are 8mins from my house) and XJ outer stubs. Either that or I could just run RCVs. Either way, I would get really any width I want, plenty of strength for a XJ, WJ brakes, crossover steering, stronger and off the shelf steering components from a WJ, perfect steering geometry/pinion angle, and a conversation starter I can be proud of.
So much for the modesty.
We all get carried away before long! Good luck with it man!
Robert
Old June 22nd, 2012, 09:16
Robert
Ha I know. Just wait, I have more in store. On another note, I located my rear axle. $150 with 33,000 orig on it. Also ordered flares and hack n tap.
Old June 22nd, 2012, 12:51
Ruh row. Wonder what this is for?
Old June 22nd, 2012, 15:01
Vanimal's Avatar
Vanimal Vanimal is offline
purdy. is it new or an oem take-off from another vehicle?
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old June 22nd, 2012, 15:08
It's a Magnusson MP90 that was a R&D unit I got directly from Magnusson a couple of years back for my other xj. Glad it wasn't on there when it was stolen... Anyway, I have another manifold that I am having machined down so I can weld a box plenum onto it to hold th SC and the air/water intercooler. Packaging is gonna be a beeeotch. This is a project for after the suspension, though.
my build project. Dulltip Arizona Chapter 14 May 29th, 2010 22:55
Project Jep: Overbuilt Overland XJ Stage 1 Build Thread Ilikeparts Modified Tech Discussion 59 March 15th, 2010 19:05
Project Great White - 97 XJ Build Thread MichaelMaxim Jeep Picture Showcase 7 January 13th, 2010 11:35
Build thread project mall crawler Wildman89 SoCal Chapter 55 October 1st, 2009 11:19
94 project build OffRoadOhio Midwest Chapter 20 February 14th, 2009 16:28
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
