Old June 9th, 2012, 20:22
995speed's Avatar
995speed 995speed is offline
Muffler inlet goes into cat outlet correct?
I'm putting in a flowmaster 40 in my 99 XJ with a 4.0 and an AX-15 my girlfriend is helping aka holding it while i clamp it in place and etc. She's insisting that im putting it in wrong because im putting the muffler inlet into the cat outlet shes telling me when her cousin worked on her car and replaced the muffler he did it outlet to outlet now i dont know a whole lot about mufflers but im pretty sure she is wrong so i said fine ill go onto and ill prove to you that i am doing it right and that once im done with my jeep im going to have to fix what your cousin did cause its wrong so basically am correct I to be putting the muffler inlet into the cat outlet and more importantly is she wrong?
Old June 9th, 2012, 20:25
MrShaft696's Avatar
MrShaft696 MrShaft696 is offline
Re: Muffler inlet goes into cat outlet correct?
wierd, alot of mufflers are the same either way but I wouldnt listen to her haha.
Old June 9th, 2012, 21:00
Outlander560's Avatar
Outlander560 Outlander560 is offline
hahaha cat out goes to muffler inlet that means exhaust is going into the muffler...then tail pipe goes to muffler outlet that means exhaust is coming OUT of the muffler to the tale pipe
Old June 9th, 2012, 21:08
souske's Avatar
souske souske is offline
Salton of Stuck
Is her cousin also her uncle?
Inlet: stuff going in
Outlet: stuff going out
The whistles go WOOoO!
SoCal VP
61/100 hours donated to SBNF AAT for 2015
Old June 9th, 2012, 21:15
995speed's Avatar
now my other issue my driveshaft is really close to the muffler did anyone have this issue as well?
Old June 9th, 2012, 21:18
Pelican Pelican is offline
NAXJA Member #1191
Don't know about your muffler but I think you just won the daily prize for the longest sentence with no punctuation! LOL
You might not want to flat out tell your girlfriend she is wrong but you could ask her nicely if her cousin by chance flunked English comprehension in high school.
Old June 9th, 2012, 21:35
i swear they should put colored stickers on these things...i've had the same problem
Old June 9th, 2012, 21:40
995speed's Avatar
i still have a problem with the driveshaft hitting the muffler did anyone else have this problem and how did ya fix it?
Old June 9th, 2012, 22:01
got a pictures? try rotating the muffler the other way
Old June 9th, 2012, 22:57
995speed's Avatar
yeah thats what i did it hit the frame a couple of times until i straightened it out properly but now its all good at least it will keep the cops off my ass. now that that is fixed i can try and think of a way to fix the sagging headliner next..... it never ends
Old June 9th, 2012, 23:20
just take it down...get spray on adhesive..and something to flatten out the wrinkles... flexible plastic bondo spreaders work
Old June 11th, 2012, 08:38
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
A proper muffler for the Jeep Cherokee application should have an off set inlet and centered outlet. If its hitting the driveshaft she is probably right and you should take advice from her. Nowadays you can find all this info on the internet before you come here and start an incoherent rambling.
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
Old June 11th, 2012, 08:45
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
pics of said GF will determine my answer.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old June 11th, 2012, 08:47
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Clearly you forgot to install new muffler bearings between the two when you had it apart
Old June 11th, 2012, 10:43
995speed's Avatar
i got it all in properly working fine now and sounds great
Another Heater Core ? Inlet and Outlet? Redsnake OEM Tech Discussion 1 February 21st, 2011 12:00
Cat Outlet size Muffler Outlet size 3fifty OEM Tech Discussion 5 January 31st, 2010 19:58
2.25" inlet CAT with 2.5" outlet, are these made? selarep Jeep Street and Performance 2 May 23rd, 2007 07:58
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
Catalytic Converter Inlet/Outlet reson46 OEM Tech Discussion 0 December 30th, 2003 12:59
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
