Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Cowl hood the right way
Though I'd share my cowl hood build.
Stripped down to metal. ![]() Marked for the cut. ![]() Cut. ![]() After goofing with the stock hood you relize how flimsy and thin they are. Just cutting and adding strips wont give the hood the strength it needs to hold its shape properly. I used a stick of .25" rod and formed the profile I needed for both sides. These were tacked to place. Next I welded uprights using the same rod to the frame work to support the cowl. ![]() Job well done, reward youself. ![]() Next I used some masking tape to create a pattern. ![]() I cut it out (a little large) and fit it. ![]() After that I ran it through my english wheel to give it some curve and bead roller to roll the shoulders. You don't need these tools to do this but it helps. ![]() ![]() |
#2
Re: Cowl hood the right way
Now I'm ready to weld it. I scribed a line with the filler panel where cleco'd and trimed the extra part of the hood off so I could butt weld it.
![]() Welding. ![]() ![]() Now to add a filler strip to the back. ![]() Screen. ![]() ![]() Skim coating. I did this to the whole hood and used a board sander to knock it down and smooth it out. ![]() Primed. I sealed it with Epoxy and did hit it with high build 3 different times with sanding in between. ![]() ![]() ![]() I blasted the bottom with lizard skin to keep it sealed and quite. Also you can see the supports I made to support the cowl in the middle. There are 4 total. ![]() |
#3
That looks nice & clean. One of the best DIY jobs I've seen.
#4
Hope this helps others wanting to do this. These hoods are thin so go slow to help with the warping. If I did it over again I'd probably cut the braces out underneath so I could dolly the panels nice and flat before skim coating.
#5
That thing is BA. Nice work.
#6
Looks great!
For fun, a shot from inside the Jeep? |
#7
Sure thing.
It's 3'' in the middle and 2 1/2" on the outside to give it a little crown and flow better. ![]() ![]() |
#8
Very Nice!
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon [QUOTE=*89Laredo*;246072645] The human skull makes quite a loud noise when it hits a metal chair. [/QUOTE] |
#9
nice work!
That's awesome, looks so great!
Thank you for the pics from inside. Would love to have that view in my rig. |
#11
WOW! excellent work!
#12
Nice work !
#13
Well done!
where did you pick up your screen?
#15
Beautifull work... Its a shame how often this is done the lazy way.
Thread Tools | |
Display Modes | |
Hood vents versus hood cowl/scoop | Tryfan | OEM Tech Discussion | 8 | April 22nd, 2012 08:01 |
cowl hood | jpcherokeekid | Sierra Chapter | 14 | November 11th, 2010 18:15 |
DIY Cowl Hood | Mr.Shrek | Modified Tech Discussion | 32 | September 7th, 2010 13:55 |
Cowl Hood vs Hood Vents | JNickel101 | Modified Tech Discussion | 17 | November 18th, 2007 05:47 |
Cowl hood | Prepmech | Paint and Bodywork forum | 2 | February 25th, 2007 16:23 |
