Old April 26th, 2012, 09:07
markg markg is offline
speedometer sender question
the one in the transfer case.mine is a 91 and has only a 2 wire connector.can i swap it for a newer 3 wire sender?the newer style is plentiful in the junkyards and mine seems to be a special order.i recently replaced my gage cluster and all of the connectors went together without any speedometer didnt work before i changed it either so i would like to try the newer sender.
question about sender to gauge freshpow OEM Tech Discussion 1 July 1st, 2011 17:29
XJ gas tank sender question veneno Modified Tech Discussion 4 January 7th, 2011 22:35
Oil pressure sender question johnnyc OEM Tech Discussion 19 July 24th, 2005 22:33
Temp sender/ engine coolant sender, same thing? Angus OEM Tech Discussion 8 March 29th, 2004 10:59
