Old April 25th, 2012, 12:41
XJRunner's Avatar
XJRunner XJRunner is offline
no start, running lights come on when you turn the key etc
Alright my Jeep wont run, it'll barley start idle for a second than sputter out. Also my running lights come on when you turn the key. I think it might be the CPS but whenever I test it I dont get any readings. What do you guys think?
Old April 25th, 2012, 18:04
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: no start, running lights come on when you turn the key etc
I think you need to provide more information. Year, engine, transmission ?
Are all your tune-up parts fresh ? Why are the lights coming ON ? What have you tested and inspected ? Why are not getting any readings on the CPS test ?
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Have the battery, and the alternator Load Tested for proper function in a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old April 26th, 2012, 02:24
XJRunner's Avatar
battery is less than a year old and mounted inside, battery cables are clean, grounds are clean. its an 87 with an 89 motor aw4
arb turn signals/ running lights seth15210 Modified Tech Discussion 11 March 15th, 2010 13:41
Keep blowing fuse #11- run/start ignition, daytime running lights johnsoninc86 OEM Tech Discussion 0 October 26th, 2009 21:04
over head lights, and parking lights wont turn off...wtf? wishihad1 OEM Tech Discussion 3 May 8th, 2009 14:03
Turn Key, and no start, no lights, radio, windows, etc LouisianaZJ OEM Tech Discussion 11 October 19th, 2008 18:19
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 16:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
