Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old April 27th, 2012, 09:58
sweetjeep sweetjeep is offline
Re: VW TDI into a 99 XJ
Originally Posted by XJCasper View Post
I actually might hate you.
How easy is a 2000 TDI to cover to biodiesel or vegi oil?
It's a common theme. Generally has more to do with my personality than my toys.
The ALH motor (1998 - 2005) is one of the easier to convert. In this case the only conversion to Bio is 2 short fuel lines and a couple o-rings.
For veggie, you need only to plumb in the hardware to pump fuel from a separate source.
Old April 27th, 2012, 19:55
I borrowed some heavy weight scales this afternoon.
Corner weights are: 897 790
737 696
Totaling: 3120 lbs.
Pretty not bad!!
The motor/trans have been moved forward about 4 inches and the front prop shaft isn't currently installed. But otherwise the thing is roughly stock ('99, 5 speed, "Classic"), factory spare tire and I suspect it had VERY little fuel in it. I am confident that when I am done and the motor is in the other body it will gain a fair bit of weight. At least a couple hundred lbs (plus my fat ass). But damn if this thing isn't respectably light!
Old April 29th, 2012, 06:15
scoobyxj's Avatar
scoobyxj scoobyxj is offline
Have fun getting the XJ gauge cluster working with the VW stuff. IIRC the XJ cluster in the 97+ are almost completely controlled by the CCD bus. and requires the XJ ECM to drive it. You will probably be better off by just building your own gauge cluster with aftermarket gauges.
Old April 29th, 2012, 08:16
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
100% correct here.
It is possible but it will not be easy.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old April 29th, 2012, 08:22
I'd like to avoid building a new cluster, but I am not opposed to it. My plan is to leave the Jeep ECM in tact and double up on as many of the existing senders as I can. For example there will be 2 oil pressure senders, 2 temp senders etc. One set for the VW and one set for the Jeep. In theory this should control everything as even if you motor is keyed on and not running the sensors respond. Which is basically what the truck will see. The speedo SHOULD work on it's own. It's really just the tach that will likely prove to be an issue.
If I go straight aftermarket it's dramatically less an issue.
Old April 29th, 2012, 08:25
kastein's Avatar
That's a stock AX15 bellhousing you said, right? And a stock XJ flywheel?
You should be able to bolt the Jeep CPS right into the usual location and connect it to the XJ ECM.
The only issue I can see is that the Jeep is going to be setting a CEL no matter what you do. So what I would do is open the Jeep cluster up, disconnect the bulb for the CEL from the wiring built into the cluster, then feed it with a wire from the VW ECM or VW cluster module (gutted down to the bare minimum, since you won't be using any of its other functionality) CEL driver.
Old April 29th, 2012, 20:26
Just in the event that anyone is wondering..
The Cherokee (with the TDI) weighs in at 3127 lbs. My 99 Cherokee with the 4.0 and a 5 speed - 3317lbs. Both trucks were very low on fuel.
And the 10,000 question to make this comparison worth anything. My 02 Jetta with a 5 speed and pretty much every option I know of and exactly 3/4 tank of fuel. 3015 lbs.
So to those wondering about weight.. There is roughly a 100 lb difference between the 2. I am more than a little surprised!
Old April 29th, 2012, 20:31
I am pretty certain it's a stock AX15 bell, yes. I am moderately confident it's out of a 97.
The flywheel however is from a Volkswagen. Though I may look a little closer as to how the CPS actually works, perhaps I can use the Jeep sensor and modify the flywheel..
I had thought about that for the cluster too. I may go that route. Though I may use a couple idiot lights also. There are lights for the Cruise (if/when), glow plugs, possibly some other stuff. At least the glow plugs..
Old April 29th, 2012, 20:38
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
This is cool!
And you're right about the weight...VW TDI's weigh a lot more than most people would think they do.
-Timbo - SEC Treasurer
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
Old April 29th, 2012, 20:56
kastein's Avatar
Interesting.
If you want to make the Jeep CPS work on the VW flywheel, what you really need to do is duplicate the flywheel edge to CPS nose air gap (mostly to make sure you even get a signal, and also don't shred the end of the sensor the first time you turn it over...) and the notch pattern on the edge of the flywheel. If you need something to measure the flywheel notch pattern off of, I have a few old flexplates out of XJs, you can have one free if you pick it up or are within reasonable distance. Obviously you only need to duplicate the pattern, no need to keep it timed right with regard to cyl #1 or anything since the ECU won't be firing any spark plugs or injectors anyways.
Old April 30th, 2012, 08:03
O-Gauge Steamer O-Gauge Steamer is offline
The Heeps flywheel has three groups of four notches spaced 120 degrees that the CPS reads for position and to generate the rpm signal to the PCM.
You would need to measure the gaps to get it right.
All things considered, it would IMO be much easier to just build a new cluster. Why fight it?
Old April 30th, 2012, 11:26
Originally Posted by o-gauge-steamer View Post
..... Why fight it?
Clearly I like a challenge.
Old April 30th, 2012, 11:27
Interesting.
I just realized where you are. I'm in Templeton. Maybe an hour and a half from you. I may make the pilgrimage down and snag one of those from you. There is a chance I can simply adapt the Jeep flywheel to work too.
Definitely appreciate the offer!
Old April 30th, 2012, 11:29
kastein's Avatar
Goddamn, that's not far at all! I almost bought a house up there actually, on School House Rd.
Old May 1st, 2012, 17:56
That would be Phillipston, but that's just next door. Small world, eh? You can be the first to come up and prove that the truck is real. hahaha!
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
