Old April 19th, 2012, 13:13
200SportXj's Avatar
200SportXj 200SportXj is offline
Difference in 4.0l Blocks per year?
Im looking to build a stroker motor for my xj, I went on craigslist and found a complete 1987 4.0l block.
From what I understand that is the very first year of the 4.0.
My question is, is the actual block identical? and can all my accessories/intake manifold/header/head bolt onto this older block.
I have a 2000 xj with a 4.0 that runs fine, so i just wanna build the 1987 in the garage and throw it in someday.
I know the connecting rods were a hair different because they moved the pin location. But i know they are both 242 cid from 1987-1992 and then 93-97 was 242 non HO, then 98-01 was the HO version which is just a different intake manifold and diff header design.
Fill in the blanks for me, thanks!
Old April 19th, 2012, 15:44
XJFrankenstein's Avatar
XJFrankenstein XJFrankenstein is offline
Re: Difference in 4.0l Blocks per year?
You will be better off with a newer block with noise and vibration improvements - check this link for a complete rundown on blocks, heads, cranks, and rods:
http://www.fourwheeler.com/techartic...six/index.html
Anorg stroker links:
http://www.angelfire.com/my/fan/stroker.html
Blocks:
Year............Casting No
1987-90......53005535 (8933002665)
1991-95......53008405
1996-98......53020569
1999-04......53010449
The main webs of the '96 and later blocks were stiffened with extra ribbing and a main bearing girdle was added to reduce noise, vibration, and harshness (NVH), making these the best blocks to build upon. All Jeep 4.0 blocks have a deck height of 9.450-9.456".
Old April 19th, 2012, 16:49
.dotfortune .dotfortune is offline
Just to get ypu some correct info, both my 96's are HO motors. And 96 is the first year for the increased webbing.
Good Luck too!
Old April 19th, 2012, 18:52
200SportXj's Avatar
but this doesnt answer one of my questions which was, will all my accesories bolt onto it?
Like my HO intake manifold, newer headers, newer head?
Old April 19th, 2012, 20:56
Tacedaddy's Avatar
Tacedaddy Tacedaddy is offline
short answer yes they will
and you will get MORE displacement (only slightly) because the stroke is longer
Read the wikipedia article on the 4.0
Old April 19th, 2012, 21:38
cruiser54's Avatar
cruiser54 cruiser54 is offline
Bore and stroke are the same...........
Old April 19th, 2012, 23:37
88_cherokee's Avatar
88_cherokee 88_cherokee is offline
I was offered a modern short block (had coils on plugs) for like $150 from a xj. It should fit right in my 88 xj i guess
Old April 20th, 2012, 02:35
200SportXj's Avatar
ya u might hit a few snags with wiring of electronics tho.
Old April 20th, 2012, 03:39
H8PVMT's Avatar
H8PVMT H8PVMT is offline
All the bosses are different on 01 blocks
'92 Briarwood stocker
Too many kids, too few jeeps
Old April 20th, 2012, 05:35
cruiser54's Avatar
When doing a cross-year swap, you use the vehicle's electronics like dizzy, flywheel, manifolds, sensors.
Old April 20th, 2012, 05:36
cruiser54's Avatar
Think they are on the 2000s, too.
I know for sure you can go to 1999 with minor adaptations.
Old April 20th, 2012, 07:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I don't think this is is true, so proof is required.
I do know that any 1991-2001 XJ or 93-98 ZJ engine block will interchange with any other. You simply re-use the flywheel (if required), manifolds, belt driven accessories, sensors, and head as needed on the donor engine block. I would think that the earlier blocks also interchange, I just don't have any threads to link to as proof.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old April 20th, 2012, 08:35
O-Gauge Steamer O-Gauge Steamer is offline
Insofar as I am sure, the COP head is the big issue, not the block. But, that being said, I would choose a later block to get the extra (read needed) main bearing support.
The blocks changed sometime after '01 so that would make mounting the accessories a tad difficult... With the AC compressor on the Driver's side for instance.
Old April 20th, 2012, 16:27
200SportXj's Avatar
Well im picking up the block regaurdless, its worth 50$ in scrap alone prolly. at 10 cents a pound and it weighing 500lbs. Ill figure it out once i get it in my hands on tuesday and ill document and post pics
Old April 20th, 2012, 21:28
Tacedaddy's Avatar
YOU ARE WRONG
The displacement differs between 1990 and 1995 and 1996–2006 4.0L engines by 2 cubic inches. Both had a bore of 3.88 in (99 mm), while the stroke decreased slightly from 3.44 inches (87.38 mm) on the earlier engine to 3.41 inches (86.61 mm) on 1996 and later engines.
GFY
Front Skid Plate - Year Difference? jbsjunk Modified Tech Discussion 10 December 3rd, 2009 20:37
WTB 1'' blocks XTurboJ InterMountain Chapter For Sale/Wanted 5 March 12th, 2009 11:41
OLDER YEAR ARB BUMPER FIT ON A NEWER YEAR CHEROKEE C85D4x4 Modified Tech Discussion 6 September 26th, 2006 18:32
New things i've done this year and my plans for next year ROBZ95Xj North Atlantic Chapter 3 December 29th, 2005 10:33
What year hitches fit what year XJ's wannabe Modified Tech Discussion 0 June 17th, 2004 22:03
