Go Back   NAXJA Forums -::- North American XJ Association > Support and Administration Forum > User Support, Questions and Suggestions
User Support, Questions and Suggestions Not Jeep Tech Questions. Forum use related questions or comments only.
Closed Thread
Old February 28th, 2012, 20:47
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Upload fail - PDF Document
I can't seem to upload a PDF. I have tried it with 2 browsers, IE9 and Chrome. The size is 2.9M.
Comes back "Upload Failed"
  #2
Old February 28th, 2012, 22:56
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Re: Upload fail - PDF Document
Can you possibly give any less information? Most specifically, what board?
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
  #3
Old February 29th, 2012, 17:24
Forum -FAQ and also here
Upload=Attach
File=2.9M PDF
Result=Failed Upload
Fix? Useful Suggestion?
  #4
Old February 29th, 2012, 18:19
MT Mike's Avatar
MT Mike MT Mike is offline
http://www.naxja.org/forum/showthread.php?t=1026618
I had the same issue until I went in and re-sized the pictures. After that, the pdf would load up just fine.
  #5
Old February 29th, 2012, 18:49
ChiXJeff's Avatar
Curmudgeon
Turns out this is not directly a vBulletin configuration like I thought it was. I'll have to work on this on a separate server here, and that won't happen until next week.
ChiXJeff
Lifetime member
  #6
Old February 29th, 2012, 20:31
lobsterdmb's Avatar
lobsterdmb lobsterdmb is offline
Just a Lobster Minion
Thanks for looking into this Jeff
Johnny
Retired President
Support , become a member!
  #7
Old February 29th, 2012, 21:53
Jeff, I appreciate your time and effort on this.
It is not a high priority. However be kinda interesting to know what's the deal if VB isn't imposing a size limit to PDFs. Hmmm...
I didn't want to break up the article into 2 pieces... However it appears that even though Word is compressing the JPG quality to 200dpi, it can be further compressed to 96dpi before assembling the pieces in Acrobat.
I will try this.
Thanks for your help guys
  #8
Old March 6th, 2012, 19:24
I extracted Pages 1-5 and 6 though 9, saved them as different names, and tried to upload them. VB replaced the upload window with a VB logo'd Database error screen when upload was complete. Happened with both files.
  #9
Old March 6th, 2012, 19:38
Tried compressing the images in word on pages 1-5 and rebuilding as a ACROBAT file.
Same result.
File size=1,743.
  #10
Old March 6th, 2012, 20:08
OK, I've been playing with chopping up the document. The upload limit appears to be around 1M, Above that and it bombs. That bites, one page alone is 460K and that's at 96dpi compression on images.
Jeff, I hope this helps.
  #11
Old March 6th, 2012, 21:02
More playing... Instead of converting the HTML document saved from the web, I cut and pasted the text and images into Word, then cleared the Formatting, and converted. The entire Document with only a couple of images dropped out for clarity, was well under the 1M size.
Jeff, you can delete this thread after you have read it.
Thanks!
Closed Thread
Rate This Thread:
Upload pic for signature? JeepFreak21 User Support, Questions and Suggestions 6 October 24th, 2008 01:05
How do I upload photos? YosemiteMatt Colorado Chapter 15 August 4th, 2008 07:03
upload pics dabeast727 South East Chapter 2 January 2nd, 2008 21:06
Can I upload my own Avatar? heyjpark1 Non-Tech / Off Topic 9 March 12th, 2007 01:36
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
