Old February 28th, 2012, 11:37
kenny811's Avatar
kenny811 kenny811 is offline
Injector Swap
I have a set 5.0 ( im pretty sure 19 LBS ) in a 89 renix. Can they be swapped into a 93 HO motor? Is there a range or limit for this swap?
Thanks
Kenny
Old February 28th, 2012, 14:47
gradon's Avatar
gradon gradon is offline
Re: Injector Swap
Those Ford yellows are rated 19#@39psi and the the brown top injectors in your '93 are rated 21#@39psi. I'm sure the pcm can adapt to use 10% smaller injectors while driving in closed loop and part throttle below 3Krpm, but when it goes to OL during >75% throttle input those injectors won't give enough fuel(lean) unless you have a map adjuster to bump up the voltage some.
Old February 28th, 2012, 15:25
kenny811's Avatar
Re: Injector Swap
They have about 400 miles on them ( the yellow ones ) So I need to find a set of 21#... Thanks for the input.
Old February 28th, 2012, 17:01
Tacedaddy's Avatar
Tacedaddy Tacedaddy is offline
Re: Injector Swap
edit nvm had to re-read
Old February 28th, 2012, 18:02
blubullett's Avatar
blubullett blubullett is offline
Re: Injector Swap
I have them in my 95 with no problems. No spark knock or anything. I even passed CA smog with them in so it wasn't running lean in normal driving conditions. I did just add the upgraded pressure regulator that is recomended for use with them and it didn't seem to make any difference.
Injector Swap Question bdenglund Jeep Street and Performance 8 January 27th, 2012 19:31
injector swap phillyxj570 Modified Tech Discussion 4 September 4th, 2010 14:26
injector swap questions CromeY90 OEM Tech Discussion 50 February 14th, 2010 22:08
injector swap cmr4by4 OEM Tech Discussion 4 January 22nd, 2005 22:25
Issue after 5.0 injector swap... sintax Modified Tech Discussion 13 April 3rd, 2004 14:31
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
