Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
Old February 28th, 2012, 10:51
Missiletech's Avatar
Missiletech Missiletech is offline
Thumbs up Anyone seen this homemade bender??
I want to die after seeing this. Oh the things that could be done is such short periods of time...
http://www.pirate4x4.com/forum/showt...=951950&page=2
http://www.youtube.com/watch?v=5NhP2...eature=related
-Steve
Old February 28th, 2012, 11:59
stumpXJ stumpXJ is offline
Re: Anyone seen this homemade bender??
Thats pretty darn sweet, way faster than most set-ups.
Old March 4th, 2012, 15:51
xcm xcm is offline
what about this one?
Old March 4th, 2012, 16:02
Now thats cool, and realtively easy looking to build. (compared to the other one)
Got a build link to that one?
Old March 4th, 2012, 16:08
xcm xcm is offline
No sorry, i dont have a winch, or a front receiver hitch, so building one was never viable.
Trying to find it now, its either from pirate4x4, or more likely offroadfabnet
Old March 4th, 2012, 21:32
2stix's Avatar
2stix 2stix is offline
not sure i like the single shear design of that one. but i give a couple points for thinking outside the box. still with the small price of the JD2 model 3 i cant seem to figure out why you wouldnt just buy one. the steel, parts, and welding involved with these others just doesnt seem to be all that economical. a cool factor but thats about it. i mean they bought the dies, why not buy the less expensive part that makes the dies work? plus the resale value is still there. just sayin.
Old March 4th, 2012, 22:36
xcm xcm is offline
All very good points....
Old March 5th, 2012, 01:01
bails85 bails85 is offline
This is so bad ass. Creative as hell. Definitely a cool factor.
Old March 5th, 2012, 13:48
Yeah, its just cool is all. I already have a bender, (go trikes) so I dont need one, but like to see what other people come up with.
Old March 5th, 2012, 23:15
I was going to do the gottrikes bender but after the time and steel prices im just going to do the jd2 route. They have the best selection of dies and that's the main part of the bender. IMO unless you can home brew the dies a home brew bender is impractical.
Old March 6th, 2012, 10:25
2stix's Avatar
if you ARE going to get the JD2, i would suggest the model 32. i have the model 3 (very old version) and wish i could upgrade. the anti spring back system is a huge plus, not to mention the model 32 can bend up to 2.50" tube, and heavier wall thickness. at only $100 more, thats a small price for the amount of extras you get.
Old March 6th, 2012, 17:38
My Go Trikes bender can and has used both the protools 105 dies, as well as the JD2 dies with no problem. When you look at it like that, you have even more options...
I had most of the steel already, and have a milling machine for the holes/thick plates, and a lathe to turn the pins. Just made the most sense for me. The JD2 is a VERY nice bender for the money, without a doubt.
Had it for almost 6 years now... Here it is using a JD2 die.
Old March 6th, 2012, 20:12
It says specifically on is site to use protools dies. Now that I know it will accept jd2 dies I might have to rethink the idea. Thanks for posting that up.
Old March 6th, 2012, 23:59
xcm xcm is offline
When your drilling the holes, and turning the pins, it runs whatever die you make it. The protools and jd2 dies are just differant enough to ensure you buy from them, hence bringing down the price of the bender. They are functionally the same bender.
If you have a mill, and a lathe, and time and motivation to burn, building your own is a no-brainer. I have neither a mill, nor lathe, and feel the jd2mk3 /jd2 mk32 is the no brainer.
Old March 7th, 2012, 06:36
Exactly my point. Not to mention the price of steel these days, I doubt seriously you could build a Go Trikes (with new steel) for less that the cost of a JD2, especially when you factor in labor. We built two of them at the same time, so it was a little easier. It took a full stick of 2" .25" wall tube just to do it, and the thick plate is pricey too.
Rate This Thread:
radius bender, roller? roll bender? xcm Tools and Garages 1 May 14th, 2011 01:26
bender lilkuff Midwest Chapter 0 June 18th, 2009 00:31
Bender? caglezxj Modified Tech Discussion 9 January 9th, 2007 11:40
bender ? rupert Tools and Garages 4 September 21st, 2006 14:04
Anyone used a bender like this?? TPI MJ Modified Tech Discussion 2 April 11th, 2004 09:16
