Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old February 27th, 2012, 18:43
AnthonyZ28's Avatar
AnthonyZ28 AnthonyZ28 is offline
Cool Tips for driving manual transmission?
I just need some general tips.. I can drive with it, but it just feels a little sketchy at this point. How long does it take to get fully adjusted to it? The reason is that I want to put some subs in my jeep but if I cant get used to driving standard, it will be for too big of a distraction. :p I've been driving standard for about 3 days.
Old February 27th, 2012, 18:55
REWSTER's Avatar
REWSTER REWSTER is offline
BACON!
Re: Tips for driving manual transmission?
give it time,you will get it
"A Good friend will bail you out of jail but...A True friend will be siting next to you saying damn we screwed up..."
Originally Posted by XJ&CHZ4ME View Post
I'd rather lick guacamole off hobags balls .
Old February 27th, 2012, 19:08
chedisme chedisme is offline
yea just time. it took me alittle while to get used to it, now I dont even realize Im shifting.
Old February 27th, 2012, 19:30
AnthonyZ28's Avatar
Ok, thats what i thought. Ill just give it time. How long though?
Old February 27th, 2012, 19:45
crimsondragon crimsondragon is online now
Each person is different. If you're talented, you'll get it in a day. Also depends on how much you drive it. Practice is key. It took me about an hour or two but I've read up on the theory and "practiced" when I drove an auto way before I got behind the wheel.
Old February 27th, 2012, 19:51
souske's Avatar
souske souske is offline
Salton of Stuck
How long until what? Until your not stalling out at stoplights? Or how long until you can proficiently wheel a M/t?
Any other clutch experience like a dirtbike?
My first car was a stick, and once I got it down, i was hooked. I have never owned an automatic, and dont plan to. Ok maybe Ill think about it when I hit 70.
As far as tips: Dont be afraid to let the clutch out, short of dropping it and stallling out/ breaking the tires loose, many new drivers slip the heck out of the clutch.
Dont throw huge tires on there until you are ready to regear, it will make learning more difficult, as well as being hard on your rig.
Dont use GL-5 lube in the transmission, it will eat your synchros.
SoCal VP
61/100 hours donated to SBNF AAT for 2015
Old February 27th, 2012, 20:04
AnthonyZ28's Avatar
How long until I can proficiently wheel it. This is my first time driving anything with a clutch. I caught on to it fairly fast. All I did was drive it up and down our gravel road a few times and I had it for the most part. The problem for me is the stop/going and turning. Luckily I havent stalled it once out on the public roads, (knock on wood) but i've been taking it very slowy at the start. And also, I find it easier to start out in 2nd gear at stoplight. Is that bad? And what do you mean "slip the heck out of the clutch"?
Old February 27th, 2012, 20:36
souske's Avatar
Salton of Stuck
Keep practicing on that gravel road, thats a great place to get the fundamentals down. Keep going over starting/stopping smoothly, this is the most difficult part to learn, just keep at it. "slipping the clutch" means to not release the clutch pedal in a timely manner, causing all the compressed farts in the clutch to heat up, and fly away.
You mentioned starting in 2nd. Is 1st gear too short ( only good for the first 10-20 feet before you shift to second)? or is there some other reason?
SoCal VP
Old February 27th, 2012, 20:52
WB9YZU WB9YZU is offline
M/T takes time to learn if you have never owned anything with a M/T, like a Motorcycle.
Take time to be smooth, quick comes later.
Fortunately, the XJ is a great vehicle to learn M/T on as it has loads of low end torque!
For a smooth start, start in 1st with the clutch in, slip the clutch some to get moving and add gas as you release the clutch further. You can do this in 2nd, but it takes more slip (read wear), and more gas (not as efficient). 1st gear in a XJ is not a granny gear like a pickup 4spd, but more like an import 1st gear. Learn that and you can drive most current M/T.
Hill starts are a bit different. With your feet on the clutch and brake, let out the clutch slowly until you feel the Jeep start to pull on the brake, then release the brake and slowly add gas. The hand brake is there to help you do all three at once, but the XJ brakes are lousy at holding the Jeep from rolling backwards unless you constantly manually adjust them, so I gave you the two pedal version.
Downshifting takes more skill. This takes patience and learning your vehicle, but is worth it. To downshift, punch the clutch and pull the transmission out of the current gear, shortly after, pop the gas, and shift into 1 step lower gear. The idea is to get the new RPMs in sync with the gear to put the engine in the power band you want to either accelerate, or use as a brake. I very seldom use my brake except when coming to a stop.
Off-Road you don't tend to shift much and the game is all Clutch/Brake/Gas coordination. You will tax your skills there.
I drove MC for years before my 1st car (a 1200 Honda Civic). I drove around a lot around on different terrain to hone my skills with the new set of parameters.
As per above, time depends on the person. I taught my 1st wife how to drive a stick in 2hrs. My Brother after days, gave up and never bought another M/T vehicle.
Old February 27th, 2012, 21:10
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Even with only 3.55s and 33s I found it very easy to get used to wheeling a stick, especially in low range. I have to do something really stupid to stall it out then.
High range is another story.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old February 27th, 2012, 21:21
AnthonyZ28's Avatar
Ok, how do I prevent the jeep from jerking a little while accelerating in 1st and sometimes 2nd? That's the most annoying thing for me. What I normally do is when I starts to happen I engage the clutch and slowly release it again. Help on this?
souske's Avatar
Salton of Stuck
3rd gear in low range is roughly equal to 3rd gear in low range. that might be some use while wheeling
SoCal VP
Old February 27th, 2012, 21:27
kastein's Avatar
that is some supreme wisdom right there
Old February 27th, 2012, 21:42
AIbandit's Avatar
AIbandit AIbandit is offline
Sounds like your traveling too slowly for the gear. Should be rare in first but at slow speeds (ie. parking) you may need to slip the clutch a little but try to avoid doing so. I usually press then let off and repeat for really slow movement. Dunno if it's better than slipping though.
As said above I like downshifting and rarely use my brake as well.
I learned on dirtbikes so cars were never a problem. Every stick/clutch is different though so each one takes a little driving to get used to.
Old February 27th, 2012, 21:46
NW-ZJ-SCOTT's Avatar
NW-ZJ-SCOTT NW-ZJ-SCOTT is offline
I think the easiest thing to learn how to drive a manual, is a Diesel.. my CTD wont die! you could be in 5th gear and drop the clutch, it will just buck until you engage the clutch again
ZJ, Atlas 4 speed
MJ, 4.0HO Shortbed
Rate This Thread:
Tips for separting the transfer case from the transmission once it's unbolted??? 90Pioneer Modified Tech Discussion 4 September 3rd, 2011 22:55
Beginner offroad driving tips jeffdean Non-Tech / Off Topic 3 February 17th, 2007 17:40
Aw4 transmission is driving me crazy, help please! project OEM Tech Discussion 5 October 22nd, 2005 16:01
DRIVING tips to save gas. summitlt Non-Tech / Off Topic 13 September 1st, 2005 08:59
Driving tips forum. Centrevillemx User Support, Questions and Suggestions 1 July 6th, 2003 18:12
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
