Old February 21st, 2012, 16:58
helliphinon8 helliphinon8 is offline
Tranny won't shift into overdrive... TCM?
I've searched all forums and found nothing. I have a '98 XJ Classic with 150,000mi and a 6in lift with 33's and stock .355 gears. The problem is that it sometimes won't shift into OD . It does shift into OD most of the time, but when it doesn't, the check engine light comes on. I went to vatozone and got the codes pulled. Two were transmission related. 1st was P0705, which states "transaxle range switch fault", speed registered and the ECM detected an incorrect input from the transaxle range sensor- probable cause- failed tranny range sensor. 2nd was P0700, which is transaxle control system fault- explanation- a signal from the transaxle control module has a fault. My ? is... has anyone else had this problem, and what's the fix? Is it just the TCM, or is it a problem stemming from bigger tires with stock gears? And if all is true.. how do I fix it? Thanks in advance. N8
Old February 21st, 2012, 17:07
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Tranny won't shift into overdrive... TCM?
Adjust, clean, or replace the Neutral Safety Switch NSS. Inspect the NSS connector for corrosion and the NSS wires for damage.
Possible causes
- Open or short park/neutral position (NSS) switch circuit
- Poor park/neutral position (NSS) switch circuit connection
- Mis-adjusted park/neutral position switch (NSS)
- Park/neutral position (NSS) switch may be faulty
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old February 21st, 2012, 17:21
Naterenfo1 Naterenfo1 is offline
Try unplugging the battery for 10 minutes to reset the TCM. I would replace the range sensor if the code persists - or at least check the wiring to be sure it is intact.
just my $.02
Good luck!
Old February 21st, 2012, 18:16
old_man's Avatar
old_man old_man is offline
Another problem can be the brake pedal switch.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old February 21st, 2012, 19:05
Tried the battery deal, but both tail lights flash only when I'm turning left with the brakes on. Freakin chryslers! Where the F is the NSS?
Old February 21st, 2012, 20:07
chassellbandit chassellbandit is offline
Shift points normal? when mine was doing that it turned out to be the TPS, but like i said, my shift points were a little higher than they used to be as well. NSS is located on the passenger side of the transmission. Look at the Go jeep website for a walk through on cleaning it. i broke two trying to get them off, kind of a PITA
Old February 21st, 2012, 23:26
jeepfreak1020 jeepfreak1020 is offline
Just had the exact same problem with mine man. Its prob the Torque Converter Clutch Solenoid. I had the same problem it wouldent shift into OD. Had a guy replace that and now she runs great again.
Old February 22nd, 2012, 00:00
the_weirdo's Avatar
the_weirdo the_weirdo is offline
Ugh
This is likely a Neutral Safety Switch issue. It is a pie-shaped piece on the passenger side of the tranny. Remove it, clean it, and reinstall it. It is very common to lose OD when the NSS is dirty. P0700 and P0705 are very often the NSS.
I'm not a complete idiot, some parts are missing.
Old February 22nd, 2012, 07:26
O-Gauge Steamer O-Gauge Steamer is offline
^^I agree. I had these codes when I purchased the 98 2 years ago. Took all of 45 minutes or so to remove, clean, reinstall and adjust. Losing the lockup is a very real possibility. Before jumping off the deep end and replacing solenoids, clean the NSS.
Unless it gets broken, there is no good reason to put in a new NSS so, do a search for the cleaning process, it is well documented here...
Old February 22nd, 2012, 10:22
Tim_MN's Avatar
It could also be the Flux Capacitor or the Di-Lithium Crystals.
Since there is a Check Engine Light and a P0705 NSS fault code, the NSS is the logical place to start diagnostics and repairs.
Old June 19th, 2012, 18:10
Possible causes
NSS is bullsh!t. I got a new one from a friend at Chrysler. NOT THE PROBLEM! But thanks for leading me to believe that was the problem. It was an un-necessary pain in the ass. THX!!
Old June 19th, 2012, 18:15
It all turned out to be the Flux Capacitor. Duh... I should've known.
Old June 19th, 2012, 18:27
So the NSS helped the reverse light problem, but nothing else. I actually drove the Jeep for 20 miles with it in the "mystery gear' between 3rd and 4th and it ended up pushing tranny fluid thru the dipstick tube and onto the exhaust. (keep in mind I have the extra towing tranny cooler too). Still, there's only 1 person that suggested another thing, jeepfreak1020 with the Torque Converter Clutch Solenoid idea. Is it my next step? Im almost ready to just sell this b!tch!! It's really starting to drive me nuts. It's my Daily driver. Fu*k japanese transmissions!!!! WTF was chrysler thinking????? Dumb bastards.
Old June 19th, 2012, 18:36
DanMan2k06 DanMan2k06 is offline
Sounds like you need to have a brew and spend a day on the interwebz, bro.
Start with some simple diagnostics, not parts throwing. You threw a NSS at it an it didn't work. I'd say verify the TCM is working correctly next.
I googled "no overdrive aw4" and COUNTLESS threads came up on the same topic. Many of which are from this forum. I'll let you take it from here...
Old June 21st, 2012, 08:59
bigalpha's Avatar
bigalpha bigalpha is offline
Oh the huge manatee
just my $.02
Good luck!
How do you know that your Jeep isn't in overdrive?
1992 XJ, 4.0, AW4, D30/D35
98 XJ wont shift into overdrive Rmart30 OEM Tech Discussion 8 November 1st, 2010 12:22
AW4 Will Not Shift To Overdrive TERRor OEM Tech Discussion 5 December 17th, 2009 14:28
Wont shift into overdrive (NEED HELP) dieselenthusiast OEM Tech Discussion 7 September 19th, 2009 22:37
Tranny Shift problem vcbuzz OEM Tech Discussion 1 January 7th, 2006 18:29
HELP....Tranny won't shift CartsXJ OEM Tech Discussion 3 April 27th, 2004 23:26
