Old February 22nd, 2012, 07:01
XJLI XJLI is offline
Re: staggered rear shock conversion
do you really know why shocks are at an "angle" when used in "trophy trucks and big money sand cars?" most of the time, the shocks are mounted at an angle to pull more travel out of a shock. say a class is limited to a 12" travel shock (not limited by wheel travel) mounting the shock to "sweep" with the axle will net more travel out of the shock by using the axle's travel arc. lastly the guys doing this on "trophy trucks and big money sand cars" are running the valving to make up for the shock's angle; hell most of the applications you're trying to cite to make your shit not stink use a coilover (that may or may not be zero-rated) AND a big ass bypass shock on each corner.
do not think some off the shelf shock can do what a 2.5 C/O and 4.0 bypass can.
Old February 22nd, 2012, 14:48
zachandandy zachandandy is offline
The shock dampens the same at any angle, if the angle of force being dampened is the same. Mounting them at an angle gives the axle greater leverage to overcome the dampening effect of the axle. Mount the same shock vertically in the same vehicle and drive it. You will feel the difference.
Old February 22nd, 2012, 17:58
stroked88's Avatar
stroked88 stroked88 is offline
The "effective" dampening force is lessened when the shocks are mounted at an angle for the same reason you can get more travel out of the shock by mounting it this way. Since the piston moves less in the shock for the same amount of wheel travel it effectively gives you more travel at the wheel out of the same shock. but also since the shock is using less of the stroke, it isnt dampening as much. Its basically "tricking" the shock into "thinking" that the wheel is not moving as much so its similar to hitting a smaller bump. atleast this is my understanding of it?
Old February 22nd, 2012, 20:37
beakie's Avatar
beakie beakie is offline
it would seem the OP has somewhat of an open mind, he came here looking for some help, received quite a few different answers... hopefully he can sift through bails BS and find the good stuff in between.
needless to say, to the original poster... skip bails' posts and go with those he is arguing against. as they say "don't argue with an idiot, they will drag you down to their level, then beat you with experience"
Old February 22nd, 2012, 20:51
Voteban's Avatar
Voteban Voteban is offline
Originally Posted by nismo5 View Post
ive had both of mine on the back side of my axle since i built my xj and they work fine even though i get crap for the angle there at all the time i dont have any crazy axle wrap or anything
According to simple physics and geometry your shocks barely work at that angle.
Now read this: http://www.4x4review.com/Features/Te...7/Default.aspx
Also, in my opinion there's no reason to mount your shocks on the same side of the axle unless you're going through the floor. In that case I'd imagine it would simplify the mounts up top a little bit.
Old February 23rd, 2012, 00:53
nismo5's Avatar
nismo5 nismo5 is offline
according to the link above my shocks are about 70% effective right ? if there at a 45* if im reading that right then how is that barely working i would think under 50% would be barely working
Leaf Sprung, Front Axle
If you have a leaf spring, solid front axle with the shackles mounted in the rear, your shock absorbers should be mounted as far outboard as possible, but with a slight lean to the rear (About 1 to 2 degrees of rearward rake for every 2 inches of lift above stock, compounded geometrically). This is because as the suspension cycles, it does so with a slight arc backwards. Transversely, a leaf sprung front axle with the shackles mounted in the front would have a slight rake forward.
Leaf Spring, Rear Axle
Your rear shock absorbers should be mounted as far outboard as possible as well, and in as close to perpendicular to the travel of the suspension. Referring to the location of the shackles above, you’ll want to rake the shock absorbers forward or aft-ward appropriately.
Contradictions
We know that we don’t live in a perfect world and that the rules of thumb above may not work on your rig depending on a series of factors, typically the most prevalent being available space and needed droop (rebound). Regardless, if you try to follow the rules of thumb above as close as possible, you’ll be able to gain the most benefit from the shock absorber as possible.
Angle of the Dangle
Old February 23rd, 2012, 06:09
whatever floats your boat dude. also, those shocks are close to a 60 deg angree.
Old February 23rd, 2012, 06:26
MoparManiac's Avatar
MoparManiac MoparManiac is offline
I'd say they're at a 45.
But they're also mounted pretty far inboard.
Either way it's the lazy way.
Old February 23rd, 2012, 08:14
nismo5's Avatar
nope there at 45*
i call bs how is welding on new mounts on the axle and fabbing up a new crossmember for the top lazy
lazy would have been to leave the pos low hanging stock shock mounts and using the factory top mounts but i felt that it was in my best interest to move them up out of the way . where im from we do alot of rocks and snow neither one is a go fast scenario and i dont dd my heep either so they work just fine for me just sayin maybe cheap but not lazy
Old February 23rd, 2012, 09:12
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
nope there at 45*
Your lazy the not lazy way would of been to run them through the floor so there working at the proper angle
Old February 23rd, 2012, 13:33
Voteban's Avatar
Fruit for nismo's thought, shocks help combat wheel hop, which is not always caused by axle wrap. With your shocks not being closer to 100% effective I'd imagine this would intensify wheel hop, which is bad, even in "a lot of rocks and snow". Wheel hop is horrible in the rocks, it almost always stops forward progress unless you're really hammering it. Throttle + wheel hop = broken parts.
Old February 23rd, 2012, 19:52
nismo5's Avatar
no im smart enough not to cut holes in my floor for shocks that probably dont ride or work any better even in the right position all rough countrys stuff is crap if i had even some decent shocks i might have went a different direction
this is great food for though although ive never really had any real bad wheel hop i could see it being alot worse if your shocks aren't helping
Old February 24th, 2012, 12:08
DanMan2k06 DanMan2k06 is offline
Christ I just wasted about 10 minutes reading this thread. Talk about physics/logic fail.
Old February 24th, 2012, 19:50
Voteban's Avatar
I just wasted about 10 seconds reading this post. Talk about useful info fail.
Old February 25th, 2012, 05:31
ktm racer 419 ktm racer 419 is offline
nope there at 45*
and as the suspension compresses they get even less effective
JKS Shock Conversion karstic SoCal For Sale 21 July 6th, 2011 11:50
Shock question for RK rear coil conversion SwampDonkeyXJ Modified Tech Discussion 14 March 9th, 2010 20:57
Anyone using JKS rear shock conversion? sanjuanxj Modified Tech Discussion 6 November 24th, 2008 15:34
shock conversion-shock question bcmaxx Modified Tech Discussion 8 July 8th, 2008 12:12
rear lower shock mount conversion Kejtar Modified Tech Discussion 17 August 27th, 2003 01:30
