Old December 17th, 2011, 22:02
5-Speed XJ 5-Speed XJ is offline
Adam's 98 5-speed Build
Posting my build here it was in the NAC
Originally Posted by 5-Speed XJ View Post
so this is what i started with
Saved up for a lift and tires
Then basically pulled off my bumpers so i made some and got a winch and sliders
Then 3.07's got really old fast so i found a 8.8 with 4.10 and rebuilt it and threw a aussie locker in it
Oh it has disks too
matching solid cover for ten bucks on craigs list and 4.10s as well
Thanks For Checking out my build so far
Old December 17th, 2011, 22:06
Re: Adam's 98 5-speed Build
Wheeled it like that for a while
Then stiffeneres
Then rear upper Shock mounts
Steering Box Brace did the yj box swap with jcr plate and a chevy pump swap
Old December 17th, 2011, 22:09
today i pulled a 84 grand waggy 44 to be swapped in non dico
Old December 18th, 2011, 09:01
slow50 slow50 is offline
looks good. what steering is that your running? and whats the purpose of the upper shock mounts on the rear?
Old December 18th, 2011, 10:33
I have the crappy rugged ridge with spacers for steering. The shock mount was to get more up travel I mounted my lower shock mounts to high so i would bottom out on crosswalks i i lean them in but they'll be going through the floor soon
Old December 21st, 2011, 10:47
djlarroc djlarroc is offline
nice build. a lot of similar stuff to what i'm going to do w/my new xj.
Old December 21st, 2011, 18:23
44 stripped and in primer
Old June 30th, 2012, 15:24
I now have Ross's SJ Mid-arm Setup
The Old
Stripped and painted
Installed
Pushed the axle 2 inches forward
Put an new to me header panel on and refinished the flairs and moved them to accommodate the 2inch stretch.
HD Offroad Engineering Shackle Relocation Brackets are ordered from
BRIANHO13
Old July 5th, 2012, 20:24
Package is in NY
Old July 5th, 2012, 20:36
UPS came today
got new leafspring bushings as well
Old July 6th, 2012, 21:00
Some stuff happened
Cappy Dark Garage pic i'll get a nice one tomorrow
Old July 7th, 2012, 20:21
daytime
Old July 21st, 2012, 09:04
2x6 rockers
got steel for my rocker replacements
started cutting out the old ones
The teaser
Mock up leg one
inside
and then there were 3
Old July 21st, 2012, 09:22
mcguyver_xj's Avatar
mcguyver_xj mcguyver_xj is offline
looking good so far just pick up a set of 1st gen shackle relocaters myself and have plans for waggy 44's in future but for now working on 241or swap and 5-speed in fall/winter
Old July 21st, 2012, 21:00
just need to be welded in and painted
3 legs a side to my stiffeners
here is a finished rocker leg going through the floor X
Front caps
End caps
Adam's 98 5-speed Build 5-Speed XJ North Atlantic Chapter 18 October 5th, 2011 21:22
Is my xj a good platform to build off of for jeep speed or VORRA. NorCalChris JeepSpeed, Prerunner and Competition Tech Forum 2 August 23rd, 2010 18:16
Cheap Speed Build Curser JeepSpeed, Prerunner and Competition Tech Forum 8 April 26th, 2010 21:35
Adam's XJ FOUND! Avanteone NorthWest Chapter 54 June 8th, 2007 09:34
Check out Adam's new custom LA's! IXNAYXJ NorthWest Chapter 17 February 19th, 2007 19:12
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
