Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > North Atlantic Chapter > NAC Classifieds
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
NAC Classifieds ONLY Local Sale Items here.
Old December 9th, 2011, 04:32
bobnoxious's Avatar
bobnoxious bobnoxious is offline
NP231/early Bronco D20 doubler
NP 231 with Box4Rocks doubler kit, early Bronco D20 with AA 23 spline input kit and twin sticks. 2.72/2.34/6.36, true front and rear H-N-L. Was installed behind an AX15 in a 95 XJ. All the BS/fitment/shifter logistics has been worked out. Install it in a weekend... pound your floor out a little, cut the shifter hole open a little, and wheel with control and great gear reduction. Also comes with speed sensor adapter and speed sensor.
Note: there is not room for a DC style shaft in the front...single joint shaft.
$1200 with trans and Tom Woods drive shafts
$1000 with shafts
$700 doubler/D20 only (with shifters)
Compared to an NP231 with SYE
Old December 12th, 2011, 07:38
bobnoxious's Avatar
Re: NP231/early Bronco D20 doubler
Cheaper than a 4:1, with more gearing and axle control
Old December 12th, 2011, 09:31
twodoorXJ twodoorXJ is offline
I wish i had the cash right now GLWS!
Old December 12th, 2011, 22:35
Actually let me see if i can get some cash together, i NEED that doubler
Old December 13th, 2011, 02:44
bobnoxious's Avatar
I know you do
Old December 13th, 2011, 06:46
chedisme chedisme is offline
You have a 5 speed right? Either way its awesome to have all that gear control. But its a game changer with the stick.
Old December 13th, 2011, 07:53
bobnoxious's Avatar
What he said!
I used to be an automatic all the way guy...until I started driving sticks that had enough gearing to go slow and not stall. Game changer! As slow as I want...and clutch popping wheel speed whenever I need it.
I can ride the brake and clutch while leaving the gas alone...creep forward up a nasty line...stop and reposition...not fall backwards...not stall...not break the tires free.
Old December 13th, 2011, 09:53
IROCthe4.0 IROCthe4.0 is offline
I really want this. Stupid xmas
Old January 5th, 2012, 07:12
bobnoxious's Avatar
TTT. Measurements indicate that this will indeed fit an AW4...I have to hang it off one to be sure.
Old January 5th, 2012, 18:29
CTeunuch's Avatar
CTeunuch CTeunuch is offline
Any interest in selling the tranny separately?
Old January 5th, 2012, 22:40
bobnoxious's Avatar
Yes...PM me. I also have the flywheel/clutch, and the rig is still here, so the hydraulics and pedal are also still available for a limited time.
Old January 6th, 2012, 08:39
clean4drxj's Avatar
clean4drxj clean4drxj is offline
whats left of the body that is in good shape?
Old January 6th, 2012, 09:13
bobnoxious's Avatar
Pretty much nothing...it's rusted in the floors and rockers, and pretty well dented/smashed. I think the hood is still straight, and the seats are still good (gray).
Old March 29th, 2012, 18:57
bobnoxious's Avatar
Sold.
Old May 1st, 2012, 15:22
mad659 mad659 is offline
Was that made with a kit or did you fab it yourself ? I know about the box4rocks kit but not for a d20 behind it. Interested on how you put this together. Is there some way I could get in touch with you? I have a late d20 j shift t case and a 231 hangin' around in n "87 xj. It looks like a real good setup.
Rate This Thread:
EARLY Bronco 44 Anyone??? saybye Modified Tech Discussion 1 April 9th, 2009 11:01
NP231 Doubler Cornfed-87XJ Modified Tech Discussion 1 February 8th, 2007 09:51
early bronco fr 44 in xj 4x4junky Modified Tech Discussion 8 May 11th, 2005 19:34
Early Bronco D44 crazy4mopar For Sale: Private Party Only. XJ ITEMS ONLY 1 February 27th, 2004 13:36
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
