Old December 16th, 2011, 04:45
Fore Wheeler's Avatar
Fore Wheeler Fore Wheeler is offline
Past MWC President
Re: Team NAXJA/Petty Cash Racing stock class KOH XJ build
This is a very clean build ('cept for the rear truss plates ).
Very anxious to see the rest.
Again, very nice work.
Dan
member #285
My build thread: Out of Misery II
Old December 16th, 2011, 06:42
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Looking very nice. I like the idea of 44s instead of much heavier 60s. gives you a bit better clearance, and certainly less weight. With the reinforcement and the lighter weight they should hold up fine.
Keep the updates coming, like to see the progress.
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2019
Not a member? Become one today, and help support YOUR club.
Old December 16th, 2011, 07:20
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Originally Posted by sharq View Post
Awesome cage! How's the shifter mounted?
I had remembered seeing this question, so made a point of taking pictures of the shifter mounts. Then forgot about this question, and until today kept asking myself "wtf did i take pics of the shifter for?"...
Old December 16th, 2011, 11:04
s14unimog's Avatar
s14unimog s14unimog is offline
right on! I'll be following along on this build. Nice tube work.
Old December 22nd, 2011, 07:58
cal's Avatar
cal cal is offline
Getting back to this. If you've ever seen Goatman drive, you know that you have to reinforce every inch of the car. Its not going to be enough mind you, but you do what you can..
The engine side of our motor mounts are being covered by Brown Dog, but we were worried about the frame side. Since the engine came out for a stroker swap, it was a good time to address it..
A little cleanup.
Getting lots of practice with the plasma cutter..
Couple of tacks and checking clearance..
Burn baby burn. Amazingly, we've only set the car on fire twice in this project.
And there we go.
Old December 22nd, 2011, 08:07
cal's Avatar
cal cal is offline
Richard decided we needed to brace the upper shock mounts too.
First, a brace from the mount to the tube supporting the bumpstop tower.
Then go back and box them in..
Possibly overkill.. but really, anything worth doing is worth over doing.
Old December 22nd, 2011, 08:14
cal's Avatar
cal cal is offline
As we learned from our jeepspeed buddies.. weld every seem.
Old December 22nd, 2011, 08:18
cal's Avatar
cal cal is offline
Front 44 is starting to come together.
Blaine at Black Magic Brakes is redoing our knuckle/brake/hub setup. I'll pick that up tonight and can start putting this bitch together.
Old December 22nd, 2011, 08:29
cal's Avatar
cal cal is offline
James has been working on reinforcing the body a bit and building some armor. I really like the way he tied the rear quarters into the existing rear bumper.
And a little bracing at the B pillar.
Thats necessary to tie the rear firewall into the body, and seperate the occupants from the fuel cell.. which you'll get pictures of next week. =)
Old December 22nd, 2011, 12:08
Missiletech's Avatar
Missiletech Missiletech is offline
Teamwork and sponsorship FTW! Outstanding project gents!
Old December 25th, 2011, 16:19
cal's Avatar
cal cal is offline
Merry Christmas!
Old December 25th, 2011, 18:56
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Did Satan Claws bring you any wrench monkeys?
President & SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old December 28th, 2011, 13:31
Goatman's Avatar
Goatman Goatman is offline
James is here right now, and for the rest of the week. Some guy from the southern desert region is supposed to be here Thurs and Fri.
We hope to get a lot of stuff done between now and Sun, and the car is going to Cal's in Fullerton on Sun.
We got our custom front brakes done and the knuckles and everything are here, so the front end will be going together. We're going to have REALLY good brakes.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old December 28th, 2011, 15:05
cal's Avatar
cal cal is offline
Try not to drink all of the beer before I get there..
Old December 30th, 2011, 12:29
IXNAYXJ's Avatar
IXNAYXJ IXNAYXJ is offline
Black Magic Brakes FTW!
Petty Cash Racing/Team NAXJA pull off an astounding 4th overall! IXNAYXJ Non-Tech / Off Topic 23 March 23rd, 2012 20:53
Team NAXJA/Petty Cash Racing is heading to Reno- IXNAYXJ Non-Tech / Off Topic 14 May 16th, 2011 08:31
Team Petty Cash is LeMons racing an XJ at Sears Point the end of March Goatman Sierra Chapter 57 March 29th, 2011 12:06
