Old September 29th, 2011, 06:52
b5blue b5blue is offline
Renix diagnostic reader?
What would I be looking for to read "engine codes" from the diagnostic ports under the hood? In other words what did dealers and repair shops use? (I have an 89 4.0 XJ.)
Old September 29th, 2011, 07:27
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Renix diagnostic reader?
The Renix has a serial output and does not store codes. It's read in real time with engine running. I think the dealers had a specific reader, and Snap-on made a module for some of theirs. I believe they're pretty rare, and as far as I know there's no handy consumer version as there is for many other systems.
Old September 29th, 2011, 08:08
If I could ID the thing I'd try to find one.
Old September 29th, 2011, 08:19
old_man's Avatar
old_man old_man is offline
I have the SnapOn "brick" that has the connections for the Renix ECU. It doesn't really do anything much that you can't do with a voltmeter. I paid about $250 used for mine. IIRC, without looking the model number was 2500.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old September 29th, 2011, 08:22
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I'm pretty sure the only thing you can't check with this is engine RPM. There's an output on the ECU that goes to the ICM and the tach in the instrument cluster that will give you one pulse per cylinder per rotation, a frequency counter or an oscilloscope and some math will get you RPM.
Old September 29th, 2011, 13:59
NAXJA Member #760
I know quite a long time ago 5-90 was trying to find the specs for the serial output to see if he could hack a serial computer connection, but it seems never to have materialized. I suppose somewhere someone on this earth must know what this thing puts out, and suspect that if one knew the specs it might not be that hard for a programmer to write a routine that reads the data on computer with serial input, but I'm not aware of anyone having actually done it.
Old September 29th, 2011, 16:40
5-90's Avatar
5-90 5-90 is offline
It's still a "back-burner" project for me, and I believe some progress has been made on figuring out the datastream on RENIXPower - but I've been busy with taking care of my wife for the last year and a half (new hip, new knee, ...) and "discretionary" projects have been suspended. Considering I've been playing physical therapist, psychotherapist, and pharmacist, I haven't had a lot of brainpower to spare in big blocks of late...
But, she's recovering nicely, so I'm starting to free up mental effort for other things.
The OEM readers for RENIX were the MS1700 and DRBII, and the Snap-On unit was MT2500 (I'm trying to find one of the latter for myself.)
I've also tracked the RENIX patent to ACTIA Corp in Elkhart, IN - but they have so far not been forthcoming with information. It's about time to write them again, I think...
Old September 30th, 2011, 10:18
There are plenty of MS2500's and components on eBay. (For a price!)
Old September 30th, 2011, 18:04
Well my buddy has a MS2500 at his shop, now if I can find the right stuff to go with it.....
Old September 30th, 2011, 21:06
cruiser54's Avatar
cruiser54 cruiser54 is offline
MS 1700 was a POS. It wasn't til DRB came out that we had a decent scanner. The Snap-On "Brick" is supposedly pretty good. I have a DRB-II with the adapter for Renix. Works well.
Old October 2nd, 2011, 21:33
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Like old man said, just get a good multi meter, and the FSM, read the Fuel Injection FSM (about 50 pages) and learn what makes the Renix tick by reading it and the posts here. An ECU reader is pretty much useless for most of the Renix problems anyway, like poor Renix sensor grounds, as the ECU, TCU and scanners were not smart enough to locate the actual problem. All they did was give a few clues.
I was planning to buy a used MT-2500 at one time, but finally decided it would just be waste of money. Many of the connections the MT-2500 or DRB-II makes to the Renix connection block are listed in the Fuel injector manual and can be read one wire at a time with simple multi meter!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
OBD 1 diagnostic set up? hightime81 OEM Tech Discussion 3 April 12th, 2010 15:03
OBDII Engine Code Reader - Check Engine Light Diagnostic - NEW BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 19th, 2006 13:00
Where to get a diagnostic code reader--How much and where??? Big Red Modified Tech Discussion 18 November 29th, 2005 11:33
Diagnostic Port Ecarlcl OEM Tech Discussion 2 January 6th, 2004 15:08
Renix ECU Diagnostic Data Stream? CheapXJ Modified Tech Discussion 2 October 9th, 2003 10:38
