Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old June 28th, 2011, 18:30
IXNAYXJ's Avatar
IXNAYXJ IXNAYXJ is offline
Petty Cash Racing/Team NAXJA pull off an astounding 4th overall!
Full Story to follow at the Petty Cash Racing Blog.
-Matt
Old June 28th, 2011, 19:06
stumpXJ stumpXJ is offline
Re: Petty Cash Racing/Team NAXJA pull off an astounding 4th overall!
Thats too cool! Congrats!
~ Stump
Old June 28th, 2011, 19:50
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
Right on Team. Pretty damned good, for a station wagon.
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old June 28th, 2011, 20:22
IXNAYXJ's Avatar
Thanks, but it was pretty brutal. We ran perfectly...and still only came in 2nd in class. The Organizers accidentally put a much faster car in our class (which we still almost beat...at the end of day one, we were only 9 seconds behind the fastest car on the track). What we really need now is horsepower...we can seriously be contenders for the overall win if we had 50 more ponies.
We have two weeks before our next race in Denver...if anybody or company wants to see an XJ be the first ever vehicle in the history of 24 Hours of LeMons to win both Index of Effluency AND the Overall win, let me know and let's make it happen. Our only chance is at the Denver race in two weeks...whatcha got?
-Matt
Old June 28th, 2011, 20:54
Glenn B's Avatar
Best of luck in Denver!
So close, wish I could make it.
Old June 28th, 2011, 21:18
DeftwillP's Avatar
DeftwillP DeftwillP is offline
Were you racing in a windows xp wallpaper?
Old June 28th, 2011, 21:39
IXNAYXJ's Avatar
Bwahaha! That's the first thing I thought of too!
The track is Oregon Raceway Park, the single coolest piece of asphalt I've ever been on...at least until December when we race at Laguna Seca.
-Matt
Old June 29th, 2011, 13:04
.40CalPatriot's Avatar
.40CalPatriot .40CalPatriot is offline
Info on the Denver Race please.
Old June 29th, 2011, 13:10
IXNAYXJ's Avatar
Here's the event info for the Colorado race:
http://www.24hoursoflemons.com/bfe2011.aspx
Should be a good time, hope to see you out there!
Old June 29th, 2011, 13:11
old_man's Avatar
old_man old_man is offline
What year XJ? If it is a Renix, make sure you are running the high altitude CPS, otherwise cut and move the CPS to give you a couple of more degrees of advance, especially at this altitude. Maybe an adjustable MAP sensor and a few minutes on a dyno to get your mixture right for this altitude. Pull the head and put in the thin Mopar head gasket. Maybe extend the pan down a couple of inches along with the oil pickup and add a windage tray. While you have the head off, touch up the ports and port match to the intake and exhaust. That should all of these together should give you maybe a 20 hp increase from where you are. Its cheating but a 4.2L crank and rods and a set of H802CP pistons. That mod could give you a lot more than 50 hp.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old June 29th, 2011, 13:13
IXNAYXJ's Avatar
Originally Posted by old_man View Post
What year XJ? If it is a Renix, make sure you are running the high altitude CPS, otherwise cut and move the CPS to give you a couple of more degrees of advance, especially at this altitude. Maybe a MAP sensor and a few minutes on a dyno to get your mixture right for this altitude. Pull the head and put in the thin Mopar head gasket. Maybe extend the pan down a couple of inches along with the oil pickup and add a windage tray.
Yeah, it's an '89. We ran at Reno which was 5000 feet and didn't do anything, but I'm all about making it a little quicker. Unfortunately I won't have the time between now and leaving for the race next week to fiddle with it...anybody in the Denver area want to help us out?
-Matt
Old June 29th, 2011, 13:21
old_man's Avatar
The CPS is DEFINATELY worth the few bucks and 20 minutes to replace. IIRC I can score one from a local factory parts guy for around $50 or less.
Maybe someone around here has a junkyard pulled sensor they would donate.
Loveland, Colorado
Old June 29th, 2011, 13:52
IXNAYXJ's Avatar
Good info, I honestly didn't realize there was a different CPS for higher altitude.
-Matt
Old June 29th, 2011, 17:53
old_man's Avatar
It gives you several more degrees of timing advance which is really needed at higher elevations. Doesn't hurt the performance at lower levels either.
Loveland, Colorado
Old July 1st, 2011, 10:45
Shorty's Avatar
Shorty Shorty is offline
IIRC, the mounting bracket is the same and the sensor is just attached a few degrees farther over. If you can score one, mark the one you remove and create a template to modify standard ones-- it should be much easier to locate and modify standard ones in the future.
joe_peters :Listen to Shorty--he has spoken wisely
Ecomike :Listen to Shorty--he has spoken wisely
X2
Rate This Thread:
Team NAXJA/Petty Cash Racing is heading to Reno- IXNAYXJ Non-Tech / Off Topic 14 May 16th, 2011 09:31
Team Petty Cash is LeMons racing an XJ at Sears Point the end of March Goatman Sierra Chapter 57 March 29th, 2011 13:06
Team Petty Cash in JP Magazine Brad M. Non-Tech / Off Topic 3 March 23rd, 2010 03:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
