Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Midwest Chapter > MWC For Sale/Wanted Forum
MWC For Sale/Wanted Forum This for private-party for-sale and wanted items ONLY.
Old May 19th, 2011, 15:10
MNxj98's Avatar
MNxj98 MNxj98 is offline
AX15 problem
the trans in my eep started leaking further investigation revealed the rear case on the trans is cracked through one of the trans mounting holes. wondering if anyone in MN has a spare laying around or knows someone who is good with cast aluminum welding. let me know guys! thanks.
Old May 19th, 2011, 15:19
962door 962door is offline
Re: AX15 problem
My dads got an ax15 all tore apart and the shafts were bad. We are in Milwaukee, WI. Kind of far but if you can't find one I can talk to him...
Old May 19th, 2011, 16:27
MNxj98's Avatar
Re: AX15 problem
well see what he wants and what shipping would be to 55128 and let me know. ill keep looking but if its a sweet deal ill probably just do that. i'd like a pic if possible too. thanks
Old May 19th, 2011, 18:10
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Re: AX15 problem
I have an AX15 on the shelf, but it's out of a 92 YJ, the tail housing will be clocked a little differently.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old May 19th, 2011, 20:39
MNxj98's Avatar
Re: AX15 problem
how much of a difference is it? and where abouts in SE MN are you?
Old May 20th, 2011, 05:33
ChiXJeff's Avatar
Curmudgeon
I don't know what the difference in angle is. I'm halfway. Etween St. Paul and Rochester.
ChiXJeff
Lifetime member
Old May 20th, 2011, 14:24
MNxj98's Avatar
Re: AX15 problem
so zumbrota? im in oakdale, just a little east of st paul. how much you want for it??
Old May 20th, 2011, 16:33
ChiXJeff's Avatar
Curmudgeon
North of Zumbrota, actually. I'm in Arden Hills every day for work,I can drop it off. I'm working Sundayd morning 0400 to 0800. It's been sitting in the garage for years. PM me your digits and a good time to call.
ChiXJeff
Lifetime member
Rate This Thread:
clutch problem.....ax15 mikejones OEM Tech Discussion 4 April 19th, 2011 08:41
ba to ax15 swap problem DurbElites Modified Tech Discussion 3 January 24th, 2011 12:23
88 XJ:AW4 to AX15 Cross Member Alignment Problem RAVC1 OEM Tech Discussion 8 July 30th, 2010 19:18
92 ax15 into 95 4.0, input bearing problem spirit of 76 OEM Tech Discussion 7 October 11th, 2006 00:22
AX15 Transmission Problem? 3pinr OEM Tech Discussion 14 October 21st, 2004 05:09
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
