Old March 20th, 2011, 18:24
FREE JEEP FREE JEEP is offline
Anybody know if Bilstein 5100 from a 4" lifted XJ will work on a 3" lifted XJ
I have a chance to get Bilstein 5100 shocks from a 4" lifted Cherokee and I have a Cherokee with a RC 3" lift. Does anybody know if they will work on mine? It would be nice to get extra flex with the 4" shocks, but I am afraid they could be too tall and would compress too early. Any help would be great.
I did try to search for some info on this, but did not have any luck.
Thanks
Old March 20th, 2011, 19:42
raze1287's Avatar
raze1287 raze1287 is offline
Re: Anybody know if Bilstein 5100 from a 4" lifted XJ will work on a 3" lifted XJ
bump stop it so they do not bottom out and run them
Old March 20th, 2011, 20:01
I thought about that, but didn't want to drastically reduce my up-travel. I know my droop will be better. Thanks for the reply.
Old March 20th, 2011, 21:02
pantherchams pantherchams is offline
I'd run them as is, I wouldnt't expect an issues. Have you measured both sets of shocks? They may not even be different.
Ben
Old March 21st, 2011, 00:44
badron badron is offline
Ben
X2
Old March 21st, 2011, 05:49
He gave me measurements of 17.5" compressed and 25" extended. I do not have measurements of mine compressed and extended. Only thing I know on mine is that the body length is 14" from bar pin to the top of the body. Sitting on level ground from bar pin to the top plate before the bushing is 19 1/8". I have the guy with the Bilsteins measuring the shock body so that I can compare. I don't know if this info helps with anybodies suggestions. Thanks
will 2006 TJ Rubicon shocks work on an XJ lifted 3"? ericfx1984 Modified Tech Discussion 0 January 22nd, 2011 14:14
Bilstein 5100 Series for 4" XJ crazy-apes Modified Tech Discussion 3 April 9th, 2010 17:03
2 Front Bilstein 5100 4.5-6.5" Lift cpolish24 Arizona For Sale/Wanted 5 September 20th, 2008 16:54
POSTING LIFTED 96 11.5" LIFTED jkilcullen MWC For Sale/Wanted Forum 6 January 3rd, 2008 17:24
bilstein 5100 shocks for 6" LouisianaZJ Modified Tech Discussion 1 November 19th, 2005 14:29
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
