Old March 11th, 2011, 09:16
scott00tj's Avatar
scott00tj scott00tj is offline
do you have to replace both rotors
Do you have to replace both rotors at the same time or can I just do one side at a time?
Old March 11th, 2011, 09:30
aparke4's Avatar
aparke4 aparke4 is offline
Re: do you have to replace both rotors
the general rule that I was told is this:
1. always replace the pads in pairs
2. The discs or rotors only need to be replaced if they are bad and the same goes for the calipers. Since rotors are installed new in pairs, if you have one side with more damage or uneven wear compared to the other side then you have another issue all together and might want to find the source of that issue.
I like to refresh everything at once on both sides... yeah it might not be not necessary but I am OCD like that and would feel the vehicle would be unbalanced or something silly like that
but if you have one worn out rotor go ahead and replace the damged unit - monitor both sides after a couple hundred miles for wear trends - and replace as necessary
Old March 11th, 2011, 09:44
scott00tj's Avatar
My issue is the wheel fell off and ground the rotor flat. I might just do both rotors and pads on either side if I can get the money.
Old March 11th, 2011, 10:09
jrowell's Avatar
jrowell jrowell is offline
Not sure what the cause of that was... but you might want to look into it! 8>)
Old March 11th, 2011, 10:16
scott00tj's Avatar
missing loose lug nuts. maybe have been tampered with.
Old March 11th, 2011, 11:13
mongolchuck mongolchuck is offline
It is not totally necessary but recommended that any brake parts are replaced in pairs for brake parity. This includes rotors and calipers. A new caliper likely has a slightly different clamping force than a good used one, and a new rotor will be thicker than an old one; both will affect braking force but not a whole lot. So, if you can afford it do both, if not one will be ok.
FS: EBC Rotors For D30 Supermanxj For Sale: Private Party Only. XJ ITEMS ONLY 0 October 14th, 2007 20:42
replace doors or replace door skins? bobby hill Paint and Bodywork forum 11 January 7th, 2007 17:54
What Rotors XJTJYJ OEM Tech Discussion 15 May 1st, 2005 09:25
93 rotors on an 01 BLKXJ33 Modified Tech Discussion 2 March 6th, 2004 07:30
