Old February 22nd, 2011, 18:23
tykby3 tykby3 is offline
Converting stock 2wd to stock 4wd
Hey guys I'm a noobie and I need some help figuring out how and what I need to modify and/or buy to convert to 4 wheel drive. I do know that I need front axle assembly, both drive shafts, transfer case, tail shaft for trans and 4wd extension housing for the trans. My questions arise when it comes to if stock 4wd stuff will work with some stock 2wd stuff ex. brakes, suspension, steering, so on and so forth.
Old February 22nd, 2011, 18:56
Skits Skits is offline
Re: Converting stock 2wd to stock 4wd
You must search, young Padawan.
That said, I'm about to do the same...here are the Cliff's Notes:
You CAN convert a 2wd transmission to 4wd, but it involves a complete teardown of the transmission - you can't just swap tail shafts. Just buy a 4wd tranny and see your 2wd.
All brakes, suspension, steering, etc will swap right over.
Old February 22nd, 2011, 19:21
stewie's Avatar
stewie stewie is offline
you are right: you will need the 4wd trans, transfer case, drive shafts, and front axle. but you will also need the tc shift linkage including the handle and the trim piece that goes on the center console.
Old February 22nd, 2011, 19:22
scott00tj's Avatar
scott00tj scott00tj is offline
...and for as cheap as you can find good used AW4s the time to rebuild a 2WD into a 4WD just isn't worth it.
Old February 23rd, 2011, 01:52
KJurasek's Avatar
KJurasek KJurasek is offline
I converted mine from 2wd to 4wd. Not as hard as you think. Find a D30 (left hand or driver side drive), AW4 from 4wd Cherokee (similar year as your vehicle is best) with the 231 J transfer case. As for t-case shifter, I went with what Novak was selling. They have a better linkage now (a cable).
Have fun and good luck.
KJ
Old February 23rd, 2011, 08:06
scott00tj's Avatar
Connect the transfer case to the transmission and lift them into position as one unit if possible. Getting to the bolts that mount the transfer case to the aw4 once in place can be a real pain.
Old February 23rd, 2011, 10:58
thanks guys, i figured a lot of the stuff was the same, i was mainly worried about the trans. I've been planning this swap for a couple years and I'm now the position where I can start to do it. Have any of you that have done this had any problems with parts from different year models, I've read somewhere that '96 has different spline count than other years. My other question is would any driveshaft work or do I have to get one for a Chrysler 8.25?
Old February 23rd, 2011, 11:32
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
your vehicle's year would help a lot. Many things (transmissions, brakes, driveshafts, transfer cases, etc) depend on year of vehicle.
the 96 difference isn't spline count, there are other differences there. mid-90 or 90 to 91 was the transmission spline count change.
Old February 23rd, 2011, 12:34
I plan on getting everything off the same donor, so I'll try to find one around my year to rob everything
Old February 23rd, 2011, 12:50
yeah... but what year is yours?
We can give you a lot more specific info if we know exactly what year yours is. Some adjacent years are completely incompatible, for instance if you have a 98 automatic and you buy a 97 donor you are wasting your money, and a 95 donor for a 96 or later or vice versa will not be ideal but will work.
Old February 23rd, 2011, 13:34
i have a 96
Old February 23rd, 2011, 19:35
faraiwe's Avatar
faraiwe faraiwe is offline
Most interesting.
Howdy, folks. Just joined. Sought for info forever, until bumped into this forum.
Got an XJ '99, 4.0l (no ABS) she's my baby, but it pains me it's not a 4x4 (back then was in a hurry to get it, so...).
I understand if I get the front axle assembly, plus transmission transfer case, front shaft plus interior trimming (extra shifter etc), it should go ok, or do I need to fiddle with the ECU, etc? If so, a same year swap from a 4x4 model would do, I suppose?
What are the success stories, and the horror ones as well? I'm looking for what I can expect to deal with.
Old February 23rd, 2011, 20:54
thats what i'm trying to figure out w/ my '96, i've been planning this for a while but wanted to know what i was getting into before i get started.
Old February 24th, 2011, 21:19
Guys could I buy an axle and driveshafts out any year or does it need to be close to '96. I've sourced a 96 trans and t-case from a buddy who's parting his out, got to him to late to get everything else
Old February 24th, 2011, 21:37
Trans could have come from any 91 to 96 and even 97s with minor work, tcase from any 96 to 01.
For the remaining stuff: front shaft from any auto 4.0 87-99, rear shaft from any auto 4.0 with the same rear axle as yours 96-01, front axle any auto 4.0 87-01 but 95-99 auto 4.0 and 92-94 auto 4.0 with abs are the best. For things to look nice get the 4x4 linkages and handle off your friend's 96, or any 87-96 4x4 auto 4.0.
Stock 98+ XJ front bumper NEW, stock Tracbar/bracket Stock fr shocks Rustys T/B xtrememtbiker85 NAC Classifieds 0 July 8th, 2010 16:47
FOR SALE: STOCK TIE ROD AND DRAG LINK, STOCK HOOD,COIL SPRINGS jack96xj SoCal For Sale 1 May 28th, 2007 19:15
converting stock ac to air compressor (okieterry maybe) BUCKYXJ Modified Tech Discussion 0 April 3rd, 2005 09:11
Stock Shackles, Stock Coils, Stock Cross bars Billy_Bathgate For Sale: Private Party Only. XJ ITEMS ONLY 1 February 19th, 2005 11:50
1 RE front extended brake line and stock track bar and bracket, stock shackles dellstopjeep For Sale: Private Party Only. XJ ITEMS ONLY 2 June 12th, 2004 17:50
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
