Old February 21st, 2011, 11:52
Redsnake Redsnake is offline
Another Heater Core ? Inlet and Outlet?
I'm going to be flushing my Heater Core out this week on my '01 to free up some heat and just try and get the cooling system cleaned up. Just trying to verify that the Top hose coming thru the Firewall f/the Heater Core is the outlet side? The lower hose coming off the water pump is the Inlet hose? Is this correct?
Does anyone have any of those nice drawings that show the coolant flow thru the 4.0 XJ?
Thanks.
Old February 21st, 2011, 12:00
techno1154's Avatar
techno1154 techno1154 is offline
Re: Another Heater Core ? Inlet and Outlet?
Thanks.
The outlet from the engine come from the thermostat housing. The water return from the heater core go to the water pump.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Bad Heater Core? Jeeperz83 OEM Tech Discussion 18 November 18th, 2007 14:17
2.25" inlet CAT with 2.5" outlet, are these made? selarep Jeep Street and Performance 2 May 23rd, 2007 07:58
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
How to access heater core...question about core? nosajwp OEM Tech Discussion 1 November 11th, 2004 13:16
Catalytic Converter Inlet/Outlet reson46 OEM Tech Discussion 0 December 30th, 2003 12:59
