Old February 20th, 2011, 16:54
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Distributor install
OK, so my dizzy was chirping and howling, figured I'd just replace it. It was not causing any running or driveability isssues, just the noise.
Here's what I did.
Removed old dist.
Rotated engine to TDC compression (with help from wife). Double checked TDC (you know, it's my wife).
Set rotor at 4 o'clock.
Set oil pump slot at 11 o'clock.
Slid dist in. It turned, engaged and seated, now the rotor is at about 5 o'clock. Put bolt and mounting hardware all back together. Done
Replaced cap (and I know the firing order is 1-5-3-6-2-4)and replaced wires.
Fired it up, and it roared to life.
The only diffference is that at idle and upon acceleration, first 1000 rpm's it's rough, not sputttering, just rough. After that it's fine.
What am I missing?? Is there an adjustment...and how could I be one tooth off if everything was put back the same way.
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
Old February 20th, 2011, 17:23
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Re: Distributor install
You're one tooth off on the distributor drive gear. You need to pop the distributor back out, spin the oil pump back just a bit, rotate the distributor back a bit, and reinstall it.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old February 20th, 2011, 21:03
ParadiseXJ's Avatar
That's kinda what I did all afternoon, guess I need to move it one more o'clock to the right...tomorrrow is another day.
Old February 20th, 2011, 21:42
iwannadie's Avatar
iwannadie iwannadie is offline
You need to account for the helical gears meshing up, start it off turned slightly counter clockwise and as you slide it in it will turn clockwise.
From what I remember anyways when I did mine.
Old February 21st, 2011, 12:25
ParadiseXJ's Avatar
I thought I had surely nailed it on the 4th try, and I did.
But I had switched the #2 and #4 plug wires. Runs like a champ now and no more noise from the dist.
renix distributor install walkthrough downhillracer OEM Tech Discussion 8 August 27th, 2011 07:41
skid plate install turned engine mount install pb_beaker Modified Tech Discussion 20 December 11th, 2008 19:07
Symptoms of getting the Distributor off a tooth on install? Redsnake OEM Tech Discussion 3 April 4th, 2008 13:24
Distributor Install rws OEM Tech Discussion 9 June 14th, 2005 08:04
Local shops: gear/locker install and tranny install Big Red Sierra Chapter 4 August 2nd, 2004 15:37
