Old January 23rd, 2011, 11:45
EvanRigged EvanRigged is offline
wj steering pitman arm options?
So, I installed a set of goferit flipserts in to my wj knuckles this weekend and flipped my modified wj steering otk...While collecting parts for this mod I ordered a stock TJ pitman arm to help correct the drag link angle. My problem came when the Tj pitman arm does not fit onto my XJ steering box (the splined hole in the TJ arm is to small). It seems like I have read about a lot of people using a TJ or YJ stock pitman arm for this mod so now I'm wondering if anyone else has ran into this problem and will a stock YJ pitman arm work? I need to correct this pretty quickly. The bump steer is pretty bad!
Old January 23rd, 2011, 11:54
NEWYXJ NEWYXJ is offline
Re: wj steering pitman arm options?
Maybe you received the wrong arm. I have a stock TJ arm on a stock xj steering gear.
Old January 23rd, 2011, 11:55
Gaius's Avatar
Gaius Gaius is offline
Weird. I'm using an XJ arm on my TJ, and a ZJ arm on my XJ. They should be all the same, since they essentially use the same steer box.
What diameter is your TJ one versus your XJ one? I have an extra TJ and XJ one here I can compare with.
But really, if you're looking to flatten, I would just use heat and a shop press to flattn the XJ one to where you need it.
Old January 23rd, 2011, 14:47
My XJ arm is on the jeep now so its kinda hard to measure but the "TJ" one measures 1" from inside one master spline to the inside of the one across from it.
The difference between the two was minimal but the new arm wouldnt even start on the splines of the steering box.
I had considered flattening out the stock arm but am not sure what the heating and bending may do to the strength of the arm.
Also can anyone tell me which arm has less drop in it between a stock TJ and stock YJ arm?
Old January 23rd, 2011, 21:14
jdbwrx jdbwrx is offline
I went with a waggy drop arm. It is longer than a stock XJ or TJ (closer in length to the WJ one) but has some drop to it (close tot he stock XJ drop). It's actually a Rough Country one that is also used for an older Bronco. I lost some turning radius when using the stock XJ arm that I wanted to get back. http://www.performanceoffroadcenter....products_id=88
Old January 24th, 2011, 09:42
comancheon33's Avatar
comancheon33 comancheon33 is offline
I just did a tie rod flip with inserts and built a drag link with one ton rod ends this weekend. I had been running with the WJ steering and an aftermarket dropped pitman arm. I also had lost turning radius when I did the swap. What I ended up doing is putting a dropped pitman arm from a mid 90s dodge 1500 same drop but was an inch longer to get my radius back. I did have to ream the taper out a bit more to get the chevy tie rods in it though. When I pulled other arm the splines were actually broken out of it. It had up and down play and would pop when turning. A few of my friends have had problems with their aftermarket dropped pitman arms also. I know from now on I will not run an aftermarket dropped pitman for an XJ or MJ. The dodge one is much heavier and fits way better.
Old January 24th, 2011, 09:44
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
this would be my major worry. I believe it will weaken the arm significantly and you will need a LOT of heat to bend something that thick.
Old January 24th, 2011, 19:08
REDDOGG.XJ's Avatar
REDDOGG.XJ REDDOGG.XJ is offline
Fire up the roof.
What about running a WJ pitman.
Old January 24th, 2011, 22:51
dellstopjeep dellstopjeep is offline
I run high steer with a 44 and gave the wj arm a go. Not quite as long as a waggy arm but close. All you have to do is triangle file the clocking points so it fits on am xj box. It seemed a little weaker than the units we normally use but I have had no issues to date!
Old September 15th, 2012, 12:57
yossarian19's Avatar
yossarian19 yossarian19 is offline
I'm willing to bet this could be done successfully by the laymen, given some information & some precautions.
The key information, I'd think, is this: What if any heat treating does a pitman arm get before it leaves the factory?
I think it's "none".
I'm making several assumptions, there. The largest is in whether the pitman arm is made of cast iron or something with more carbon than mild steel.
Since low carbon metals can't really be tempered, all that is left is to heat the whole thing evenly before bending it (I'd think in a press) & to let it cool slowly.
Right?
But, then, PORC sells the part for $50... so maybe it isn't worth the worry.
Old September 15th, 2012, 13:26
Vanimal's Avatar
Vanimal Vanimal is offline
pitman arms are forged.
why not fix it the right way and change your track bar bracket?
I have wj knuckles with 1 ton OTK steering, and i can go lock to lock with the stock xj (and now ZJ) pitman arm. No need for a longer one unless something is wrong elsewhere.
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
steering box/pitman arm Q's kmanxj5050 Modified Tech Discussion 10 July 9th, 2009 04:57
Steering conecting to Pitman arm???? jdxj Modified Tech Discussion 1 November 30th, 2008 00:09
Yj steering box with xj pitman arm?? _MURDERED OUT_ Modified Tech Discussion 5 October 26th, 2008 11:31
high steer pitman arm options bj-666 Modified Tech Discussion 1 February 9th, 2007 19:52
Is my steering box/pitman arm ok? Please help. --pic-- IndyXJ Modified Tech Discussion 4 October 28th, 2005 21:53
