Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old December 4th, 2010, 00:07
Metal Head's Avatar
Metal Head Metal Head is offline
Homemade Trailer Tent ideas?
I have a small trailer I tow (wood and square steel), it's like 3 1/2 feet wide and a little over 6 feet long. I'd like to make it into a tent trailer to stash myself and the wife and kid in when camping etc. Something up off the ground and dry. I'd like maybe to add some sides maybe that fold out and make it wider with poles to hold them up and maybe mount/setup/attach a tent on it somehow. Or create a structure to drape some heavy canvas over (like a lean-to). Any ideas? I have seen these around but I am having trouble coming up with some ideas, I know people have made these themselves. Pics would be the shizzle.
Thanks.
Old December 4th, 2010, 00:45
PhotographerMike's Avatar
PhotographerMike PhotographerMike is offline
Re: Homemade Trailer Tent ideas?
I sold a Tradewinds tent trailer a couple of years ago that had a body that measured 4 x 6 feet and opened out triple to 12 x 6 feet with a tent that covered the top.
Here's the website with info; http://www.popupcamperhistory.com/tr...dsimages.html#
Click on "1965 Mar-Apr Better Camping" to see the one we had, send a P.M. with your email and I can send some photos of ours set up and closed.
Mike
Old December 4th, 2010, 07:35
stumpXJ stumpXJ is offline
www.expeditionportal.com
Look under the trailer section, be prepared to spend a little time. Lots of great ideas there.
~ Stump
Old December 4th, 2010, 11:42
tbburg's Avatar
tbburg tbburg is offline
Check out Go-jeeps trailer:
http://www.go.jeep-xj.info/Trailers.htm
You might also want to go through his trailer links for more ideas:
http://www.go.jeep-xj.info/Links.htm
(look about half way down the page)
As always, the rest of his site is packed full of good ideas too:
Old December 4th, 2010, 12:46
Metal Head's Avatar
Hmm thanks for the links. Most of these are pre-made tents though I need some ideas on making my own. I'll keep looking. Great links.
Old December 4th, 2010, 18:04
Darky's Avatar
Darky Darky is offline
Copy the premade ones, see how they're made and use those ideas when designing yours. That's how most people go about it. There's a great one in our Tow rig forum
http://www.naxja.org/forum/showthrea...ighlight=m101a
Old December 4th, 2010, 21:04
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
We have this great Adventure Forum, and there are lots of trailer idea threads in there. A number of folks start with a Military trailer, but there is no reason why you can't start with something a bit more austere.
As Darky suggested, look at how the manufactured ones are made. I'm thinking google for "adventure trailer".
Old December 4th, 2010, 22:52
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
That forum is one of the perks of being a suporter and or member IIRC.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old December 4th, 2010, 23:02
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
It is viewable, but not postable.
Old December 5th, 2010, 01:43
DrexelSpivey's Avatar
DrexelSpivey DrexelSpivey is offline
Send a pic of what your working with.
Old December 5th, 2010, 11:05
tbburg's Avatar
I wouldn't start with a military trailer. Nothing wrong with them, but they are WAY overbuilt, and consequently twice as heavy as they need to be for camping. It doesn't matter much if you keep to the trails, and never take it off road, but if you want a truly off-road-able trailer, weight is important.
Old December 5th, 2010, 15:41
BenDiesel BenDiesel is offline
i been thinking of building a trailer with a pop out tent ontop like this
but want it with a pop out range and sink and a slot up the middle big enough to fit my xr600r
Old December 5th, 2010, 16:24
Metal Head's Avatar
I also am having the delimna of whether or not i want to continually haul my ATV if so there is not much I can do with it. Being that my Cherokee is basically stock I can't pull it down too many trails lined with stumps and logs and rocks etc. anyway. Tire size may be an issue as well, the spring perches on this trailer are only 3 inches shorter than my 8.8 so a swap to my D35 for use as a trailer axle may be an option.
Here are the pics, this trailer is stout as hell for being so small I have hauled everything on this thing.
Old December 7th, 2010, 13:40
Darky's Avatar
Could you build it with walls high enough to cover your quad and then put a lid over it to mount the RTT on? Also, I would consider using just a straight beam axle instead a D35 or other driven axle. Better ground clearance, lighter weight, etc.
Old January 3rd, 2011, 22:05
DrMoab's Avatar
DrMoab DrMoab is offline
I just saw this and had to respond....
You might be right if you are thinking of the new M101 trailers they pull behind the Hummers but this just isn't the case if you can find an old M416. Bone stock they weigh around 600Lbs and while they are built well, they are in no way overbuilt. It's what mine is built on and I wouldn't want it to be built on anything less substantial.
Rate This Thread:
Anyone have a pop-up tent trailer? JoesXJ Non-Tech / Off Topic 56 October 9th, 2011 06:28
Tent trailer.. SanDiegoOverland SoCal Chapter 16 March 22nd, 2010 16:52
Tent trailer ROOK1 InterMountain Chapter For Sale/Wanted 4 January 8th, 2009 17:04
M-16 Tent-trailer SCW Non-Tech / Off Topic 4 June 12th, 2007 15:39
