Old November 24th, 2010, 11:50
hightime81's Avatar
hightime81 hightime81 is offline
CCV valve cover elbow question
Hi All!
on my 93' 4.0 XJ, there are two elbows on my valve cover.
the front elbow (as in closest to the radiator) is free-flowing, and is connected to rubber hose going into the airbox (just like every other stock early 4.0 HO engine).
the rear elbow is connected to smaller hard vacuum line and it is routed back into a port on the intake. this elbow is by-design restricted.
so I'm at my local Adv Auto talking to the parts jockey trying to find the rear elbow, (b/c i believe either the grommet is toast or there is a pinhole leak in the hard plastic somewhere causing an AWFUL whistle), and when he pulls up the part, it is the free flowing elbow and it says it is for the rear of the valve cover.
I ASSume that they just used a stock picture for both elbows, but wanted to check with you guys as well. the restricted elbow goes in the back of the valve cover, right?
thanks!
Old November 24th, 2010, 12:00
casm's Avatar
casm casm is offline
Re: CCV valve cover elbow question
Yeah, I ran into the same thing on my 2000 a couple of weeks ago when I did the valve cover gasket. Summary: Advance (and Autozone) have it wrong.
Correct.
FWIW, I ended up getting mine from the dealer - they had them in stock for about a buck more than Advance / Autozone / NAPA, all of whom didn't know exactly what they were ordering but would require four or five days to get it there.
Old November 24th, 2010, 12:02
hightime81's Avatar
excellent. thank you very much.
Old November 24th, 2010, 13:25
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Team Cherokee had the elbows,lines and grommets on special awhile ago.
www.teamcherokee.com
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Lines from valve cover to intake, and from valve cover to air cleaner. Dozer11B OEM Tech Discussion 8 September 27th, 2016 18:52
CCV valve cover elbow piece-how to remove? 95 4.0 my2monkeys OEM Tech Discussion 4 March 1st, 2010 22:39
Valve cover question JeepArg. OEM Tech Discussion 11 December 14th, 2007 09:59
valve cover question cykaaro OEM Tech Discussion 16 August 6th, 2005 19:54
valve cover question...? soulslngr OEM Tech Discussion 7 February 20th, 2004 06:03
