Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old November 19th, 2010, 07:22
RIDERED67 RIDERED67 is offline
Can the Ignition switch causing gauge cluster trouble?
Hey guys, I'm starting a new thread with a new question and updated info about my on going gauge cluster malfunction. My jeep is a 1998 sport with 170k. My entire gauge cluster does not work with the exception of the turnsignal and highbeam indicator lights. I did a voltage test of the 20 pin terminals on the gauge cluster conecters. Of the twenty terminals only a few of them had a minimal voltage reading, two showed 12.5 volts regardless of the ignition key position, and the rest were dead with 0 volts. Also recently my jeep has been intermediately starting, it sometimes takes 15-20 turns of the key(from off to start) to get the jeep to crank. So my questions are,
-Do the power wires for the gauge cluster run through the ignition switch?
-Is it possible that I have a faulty ignition switch and it is causing my guage cluster to not work?
I know I have to do some more testing to pinpoint the starting issue but I'm at work now I'm thinking about stopping by the salvage yard on the way home and grabbing an ignition switch.
Thanks!
Old November 19th, 2010, 10:13
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Can the Ignition switch causing gauge cluster trouble?
Dead instrument panels are common, search for No Bus threads for more info. There is a Technical Service Bulletin that relates to dead gauges and replacing the 20 pin connector with an updated connector.
If your Crankshaft Position Sensor (CPS) is failing or failed you will have difficulty starting and dead voltage and gas gauges are a possibility. Test the CPS for failure. Replacing a failed CPS will restore the gauges function.
Originally Posted by bimmerjeeper
I spent a few hours researching how to jack up an XJ, but even this is more complex than a normal car.
Old November 19th, 2010, 10:54
joe_peters joe_peters is offline
Yeah, this is a new thread he started instead of continuing with his original thread.
OP--starting a new thread causes the same suggestions to be rehashed over and over.
Yes. Power to the instrument panel gauges is switched power.
Old November 19th, 2010, 15:11
Hey all, first thanks for your help!
I started a new thread because the old one no longer applied to my problem. My old thread was titled "should I replace my gauge cluster" and since the time I started that thread I learned that I do not need to replace it. In my defense I started a new thread to ask two questions; Do the power wires for the gauge cluster run through the ignition switch and could a faulty ignition switch cause a gauge cluster malfunction. I'm happy to report that the answer to both of these questions is YES! I dropped in a new ignition switch tonight ($37.00 from pep boys) turned the key and boom, all gauges work, all lights light, ready for takeoff!
To sum it up in case someone is suffering from the same problem; I was fairly certain that I was not suffering from the common "no bus" faulty wire connections at the rear of the gauge cluster since all of my gauges were affected, not just the tach and speedo as related in the tsb. Also I was not experiencing intermittent gauge gauge function, they just all stopped working one day at the same time. Also, when I turned the key to start the jeep I could hear a shorting buzz sound coming from the ignition switch but it took me awhile to realize the sound.
Now I do have one more question but I'm not going to start a new thread for it
My gauge cluster is fully functional now however the airbag dummy light is on. I don't have a scan tool. Any ideas on something simple that could trigger the light?
Thanks again!
Old November 19th, 2010, 18:22
Possible clock spring issue, get it scanned at a chain parts store.
Change gauge cluster to full needle gauge cluster. QuillsXJ OEM Tech Discussion 2 February 7th, 2010 06:59
Gauge cluster and heater switch -96JeepSpeed- SoCal For Sale 0 March 31st, 2009 22:45
ignition switch bad causing battery drain? davehoose OEM Tech Discussion 3 June 12th, 2007 10:34
I'm so bored that I'm causing trouble on NAXJA!! Jump This SoCal Chapter 7 April 1st, 2007 01:51
Ignition switch trouble with an 87 Jeep the_bandit87 OEM Tech Discussion 2 June 15th, 2004 08:11
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
