Old November 2nd, 2010, 14:34
DieselSJ's Avatar
DieselSJ DieselSJ is offline
thermostat housing bolts
1991 4.0
Bolts were pretty rotted so of course one broke when I was torquing it. I thought I'd just hit the dealership for replacements but nope...discontinued and they could not even tell me what size.
Anyone happen to know what size they are? If I was smart I would have measured or brought them with me today, but I figured the dealer would know the size. I want to hit up the bolt place on the way home, so if anyone has the size I'd greatly appreciate it.
Thanks!
Mark
GadZooks Racing - Jeepspeed 1717
Brought to you by 4 Wheel Parts, Bilstein, Rubicon Express, General Tire, Rigid Lighting
http://www.facebook.com/pages/GadZoo...3613279?ref=ts
99XJ-4.0/AW4/242 87GrandWag-6.5 turbodiesel
Old January 24th, 2011, 11:19
seigeXJ90's Avatar
seigeXJ90 seigeXJ90 is offline
Re: thermostat housing bolts
did you ever find out because i'm going through the same thing? just called them and said it was discontinued
Old January 24th, 2011, 11:21
DieselSJ's Avatar
Just took them down to my local Ace Hardware (awesome bolt selection) and found some that were a perfect match. Cost me about $1.10 for both.
Old January 24th, 2011, 11:37
seigeXJ90's Avatar
you don't still remember that size do you? The place I took my head in for a valve job lost it and I don't feel like dealing with them to buy me a new one... the bolt I don't have is the long one (upper right)
Old January 24th, 2011, 12:19
DieselSJ's Avatar
I remember they are 5/16x18 thread. Don't remember the length. It was a standard size though - it wasn't some funky length.
Old January 24th, 2011, 13:32
seigeXJ90's Avatar
cool thanks.. i'll just bring the housing then and find one that fits
Old January 24th, 2011, 14:20
seigeXJ90's Avatar
just added info in case anyone else searches for this... i found a thread on another forum that has the info after i searched the specs you gave me:Upper thermostat bolt: 5/16"-18 x 1-1/2"
Lower thermostat bolt: 5/16"-18 x 3/4"
Old January 25th, 2011, 22:49
joe_peters joe_peters is offline
If you use SS studs and loctite it will make things easier next time.
Old January 26th, 2011, 09:46
OkieXJ's Avatar
OkieXJ OkieXJ is offline
x2, I would after working with water and metal, definitely go with Stainless if they are available.
'91 Laredo 3" lift, 16" Moabs, Conn-Ferr rack, C4x4 front bumper, APN header
'87 MJ, 2.5L, 2wd, in the process of "restoring"
Old January 26th, 2011, 13:39
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Home Depot has stainless steel hardware. Not sure about studs but the bolts are under the eye hook section between the lag bolts + carriage bolts and the bins of specialized hardware (grade 8 is here) at my local store.
Thermostat Housing Shogun Modified Tech Discussion 4 June 12th, 2010 16:57
thermostat housing help!! CBB311 OEM Tech Discussion 10 January 22nd, 2009 22:18
thermostat housing 4.0L dude in an xj For Sale: Private Party Only. XJ ITEMS ONLY 0 May 30th, 2007 18:24
Fun with the thermostat housing BIGSLVRXJ OEM Tech Discussion 0 January 29th, 2006 19:51
Water pump and thermostat housing bolts the_bandit87 OEM Tech Discussion 0 August 14th, 2005 15:40
