Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-28-2010
userbmx1315's Avatar
userbmx1315 userbmx1315 is online now
Low Budget
lower my jeep a lil
i finally ordered some shackle relocation brackets. well now i'm needing to lower it about 1.5 inches
i have 5.5 re leafs
rc shackles with 2 holes 1.5 and 2" lift
i put my shackle at the angle i want it and now its still 1.5" to tall.
i even put in the 1.5 lift hole in the shackle.
i'm eathier thinking 1" shackles
or removing leafs
or trading out my 5.5 springs for some 3"
98 XJ. 7" lift. 35" BFG M/T's. d30/locked44 geared 4.56. swing out carrier winch bumper, 4.6 stroker.
Old 07-28-2010
92xjunk's Avatar
92xjunk 92xjunk is offline
Re: lower my jeep a lil
You could run stock shackles or mj shackles should work cheap and easy, but if your lift is real new keep the RE shackles for after the springs are "broken in"
Old 07-29-2010
Low Budget
springs are broke in. thier rc shackles.
if i do mj shackles, will it still flex the same?
Old 07-29-2010
WaXJ_Skier's Avatar
WaXJ_Skier WaXJ_Skier is offline
<- Rockstar
see if you can find some 3.5" Leaf packs and put the shackle back at the 2" hole or you could try removing a leaf from each pack and see if that still works for you.
Shirts: Because if You stop wearing shirts, You'll probably stop wearing pants, and nobody wants that
92-4.0/AX15/231 ~6" lift Clayton long arms
35x12.5 BFG KM2's on 15x8s
Front Waggy width HP44/ Rear XJ D44 4.88 Aussies F/R
Old 07-29-2010
sunburned sunburned is offline
I'd say smaller leaf packs. If you get real short shackles for your big leaves, you are gonna lose a decent amount of flex because the springs won't have room to stretch out as they flatten.
Old 07-29-2010
FordGuy's Avatar
FordGuy FordGuy is offline
You can also have the leafs de-arced real easy, find a spring guy and have them take out a inch.
Old 4 Weeks Ago
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Now with Front Dig!
you could remove a few leaves from the pack too...
Thats what I did when I re-located my shackles...
but then I had to build a traction bar.
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . 35's and under Cal Rocs competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by old_man View Post
Everybody likes to make suggestions for someone else to do. I saw way too much of that.
Old 4 Weeks Ago
WaXJ_Skier's Avatar
<- Rockstar
I thought you hated you rig?
Old 4 Weeks Ago
Low Budget
dont really want to build a trac bar fo the rear lol.
Old 4 Weeks Ago
nochance9's Avatar
nochance9 nochance9 is offline
I'd go with smaller leaf pack, keep the relocation brackets and long shackles for flex.
I'm about to order the relocation brackets, but i'm waiting till i have money enough for some 3.5" leafs. Then i can keep my longer shackles. Should flex like mad when all is said and done.
"If you can't fix it with a hammer it's an electrical problem."
89 limited, D30-Ch8.25, 4.56's, 35 Km2's, 5.5" lift and LA's.
01 limited, LPD30-D35, ARB's and 4.56's, 33 MTZ's, 4.5-5" lift and RE drop brackets.
Old 4 Weeks Ago
Low Budget
i'm lookibg at some full width axles. if i do get them, then i wont care for the extra lift cause i'll be finding bigger tires
Jeep Lower Fourty yankeefan303 Colorado Chapter 8 11-06-2009 22:31
Jeep Cherokee rubber lower engine shield tcharon For Sale: Private Party Only. XJ ITEMS ONLY 0 01-19-2009 10:15
Decided to lower the jeep again Fullsizexj Modified Tech Discussion 11 08-21-2007 13:13
I think I want to lower my Jeep. Phil Sierra Chapter 7 06-09-2005 17:46
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
