Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-27-2010
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
A smoggin' I will go...
I'm heading to the smog station today with the MJ. 88, 4.0, 5 spd. This baby hasn't been smogged or registered since 2007.
I have done:
O2 sensor
Coolant Temp Sensor
All engine vac lines, CCV etc.
All HVAC vac lines
All T/C vac lines
Cleaned out the valve cover & baffles
New gas cap
Charcoal cannister lines
Checked EGR and EGR solenoid function
Plugs, wires, rotor, fuel filter, changed oil. Radiator, hoses, pump etc.
What have I missed. Any red flags??
Engine runs great, doesn't overheat, this is CA so there's no "inspection" other than under the hood and the gas cap. The rest of the truck is a work in progress.
I don't know if I know anything at all, but I sure know I don't know everything.
1990 XJ, 4.0, AW4, Open Cooling, 3.5" full pack. Bunch of other mods.
1988 MJ, 4.0, 5 speed, open cooled, work in progress. The MJ project: http://www.comancheclub.com/forums/v...hp?f=7&t=22382
Old 07-27-2010
kastein's Avatar
kastein kastein is online now
wheelin' on 10 42s
Re: A smoggin' I will go...
Drive it on the freeway a bit before you bring it to the station, throw a can of that GTP stuff in it, maybe clean the throttle body?
DD "dirty POS": 91 MJ, 4.0+AW4, D30/D35, Northeastern Speed Holes; future: C8.25, NP231
tetanus taco: 96 XJ, 4.0+AW4+NP231, D30/C8.25, 3.5", 33x11.5 ATs, OBA, OHC, Northeastern Speed Holes, flintstones floor option; future: more floorboards
Prototyping/testing rig: 98 XJ, 4.0+AW4+NP231, D30/C8.25; future: SYE, 8.8, 4.10s, 33s, bumpers, 0-3" lift
1958/1990 Jeep M54A2, multifuel LDS465, Spicer 6352 5-speed trans, Rockwell T138 transfer case, 5 ton Rockwell axles, 42s, future: 46" Michelin XMLs
Old 07-27-2010
ParadiseXJ's Avatar
Well, the MJ was about to pass with flying colors. All the engine test came out clean as a whistle. The last test, CA emissions Evap. Pressure Test. FAIL.
The problem is that there are 2 vents in the top of the tank, each has a hose to it, they tee off and go into the vapor return line to the charcoal cannister. In the test they pressurize the tank and pinch off the return line at the cannister. If the tank holds the pressure for ~2 minutes, you pass, if not FAIL. That is you fail the whole thing, no smog, no registration.
So I dropped the tank. There are 2 grommet dealio's that have a nipple on them for each of the vent hoses. One of them is gone, one is broken. Does anyone know what these are called, where to get them or ???.
Old 07-27-2010
kastein's Avatar
wheelin' on 10 42s
I think they are rollover valves but I'm not sure. If joe peters doesn't have the info (I know he found it at one point) I'll try and remember to look it up in my parts catalog at work tomorrow.
Old 07-27-2010
Shorty's Avatar
Shorty Shorty is offline
what would stop you from plugging one and allowing the other to run to the charcoal canister? As long as it's vented and still sealed when the hose is pinched, no one would know if there were one or two vents.
Old 07-27-2010
ParadiseXJ's Avatar
I am leaning towards the plug idea. I think just one vent would do. Both for the test and functionality. Maybe some RTV??
Old 07-27-2010
Shorty's Avatar
pull the vent and replace it with an "expanding freeze plug"-- one of those that you tighten a nut to expand-- best chance that it'll seal. Stick the tank back up and "play stupid" if something still fails.
I'd change the gas cap as well, since it is responsible for sealing/venting the filler neck on the tank.
Old 07-27-2010
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
You need two of each:
J536 0058 VALVE
J536 0059 SEAL
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 07-28-2010
5-90's Avatar
5-90 5-90 is offline
NAXJA #215
Don't forget to replace your fuel filler cap, if it didn't get checked separately (they usually do, but sometimes not.) You can fail EVAP on the filler cap as well...
"I'm looking over/my dead dog Rover/that I ran over with my lawnmower!"
KWiP Tech Index - www.kelleyswip.com/tech.html
KWiP Parts Exchange - www.kelleyswip.com/exchange.html
Old 07-28-2010
kastein's Avatar
wheelin' on 10 42s
J536 0058 VALVE
J536 0059 SEAL
Aaaaand Joe wins! Those are the numbers.
Per the OP, fuel filler cap already replaced. Feel lucky, I had to replace my filler neck as well due to a rust hole, not because of smog restrictions but because the MJ smelled like it was gonna explode!
Old 07-28-2010
ParadiseXJ's Avatar
J536 0058 VALVE
J536 0059 SEAL
...are those dealership numbers or ??
NAPA had no idea...well they had an idea...but they've "never carried them". Is it possible to do a "hardware store" fix on these? At this point I'll do whatever it takes, even a new tank since this one is 22+ yrs old. I just wish the PO hadn't futzed with it.
Old 07-28-2010
kastein's Avatar
wheelin' on 10 42s
Those are MOPAR numbers - you can google for them (take out the space) and any number of sellers will appear. Morris 4x4 appears to have the valves for $11 and the seal (which has been superceded by 5201 8823) is the same.
Looks like the seal can be swiped out of 93-96 ZJs as well, and my SWAG is that 84-96 XJ ones will work too. The valves are listed as being the same as 84-96 XJs, so the junkyard may be a good place to head for.
Old 07-28-2010
gradon's Avatar
gradon gradon is offline
Jeepride
I'm glad my 88 eliminator is registered historic, so I can avoid inspections all together, although it'd pass before my 96 and m3 would.
Old 07-28-2010
Saudade's Avatar
Saudade Saudade is offline
CA started using the Low Pressure Fuel Evaporative Test (LPFET) in 2008 to test the integrity of the evap system. This test is done only on vehicles older than 1995. After that, OBD-II tests the readiness of the evap and they take it's "word" for it.
You mentioned you changed the canister lines. I did on mine as well before smogging last month. I noticed one of the lines had a small restrictor in it. It went into the nipple on the canister, but it pulled off with the hose. Luckily I saw it and put it back in. Not sure what effect it has but it listed in the parts guide as a metering plug.
Old 07-28-2010
joe_peters's Avatar
Paying it forward
Yep, dealership. I see Kastein has posted up some good additional info for you.
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
