Old July 25th, 2010, 22:26
in4aride's Avatar
in4aride in4aride is offline
making late model 1/4 guards/light boxes work on early model
doable?..what the difference?
anyone done it and have any advice/tips?
i know they dont fit prefectly due to the light shape and the hatch shape, but aside form that....anything?
Grab a gear, let's go.
Old July 26th, 2010, 18:44
JeepCherokeeGuy99 JeepCherokeeGuy99 is offline
Re: making late model 1/4 guards/light boxes work on early model
which guards are you talking about? thor's or jcr's? i have the 97-01 jcr and it would work on a pre 97 if the light boxes were cut off.
Old July 26th, 2010, 18:51
in4aride's Avatar
some homebrew ones a guy here made
Old July 26th, 2010, 18:54
gotcha..ya well the body line is the same minus the hatch. So, cut the boxes off and sell them to a 97-01 owner and then buy jcr's 84-96 light boxes.
Old July 26th, 2010, 23:58
mcantar18c mcantar18c is offline
Mike just massage the boxes a bit here and there with a flap disc and some bondo work, then paint em. Hell I'll help ya do it. Shouldn't be too hard.
Old July 27th, 2010, 00:25
in4aride's Avatar
i think ill leave the boxes on even if the hatch is square and box is rounded...just didnt know if the 3 mounting bolt holes were in different locations
Old July 27th, 2010, 00:34
Bolts should be the same, knowing Jeep.
And the rounded boxes on the square hatch will probably be unnoticeable by most people.
Old July 27th, 2010, 05:35
jcroffroad jcroffroad is offline
www.jcroffroad.com
The are not even close. We use different side panels and the tail light boxes are WAY different between the two body styles.
Old July 27th, 2010, 09:28
in4aride's Avatar
whats the differences?
Old July 28th, 2010, 08:07
www.jcroffroad.com
The hatch is wider on 97-up, so the light boxes are substantially smaller. The tail lights on the 96-down still about an 1" lower then 97-up.
Difference between early and late model AW4's dave92cherokee OEM Tech Discussion 17 March 28th, 2010 21:52
Difference in body sides between early and late model??? WheelinJR OEM Tech Discussion 5 July 2nd, 2008 20:59
early model XJ rear steel tail light boxes RWKHausSupply For Sale: Private Party Only. XJ ITEMS ONLY 8 December 21st, 2006 22:43
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
