Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-19-2010
xj2001jz xj2001jz is offline
Unhappy 01 headlights, tail lights, no dash or center console...headlight switch?
This past Saturday I started up the jeep, pulled the headlight stalk, headlights and taillights work but not the IP or center stack. Yes, I tried spinning the stalk back and forth several times. When I turn it all the way the interior dome lights come on but not the IP or center stack. I also checked the fuses.
Any ideas? My guess is headlight switch? if so, any idea which one to get?
Thanks all!
Old 07-19-2010
CharlesS's Avatar
CharlesS CharlesS is online now
Re: 01 headlights, tail lights, no dash or center console...headlight switch?
Thanks all!
Did you even check the fuses behind the passenger side kick panel?
1998 4.0L AX-15
Old 07-19-2010
I did, they are all visually ok...
Old 07-19-2010
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
NYET! Test with a 12 volt test light, a voltmeter, or pull them out of the circuit and check with an ohm meter.
Fuses are never "visually Ok".
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 07-21-2010
TheNerd TheNerd is offline
"Fuse 6" governs all the interior lighting (switch, x-fer case, IP, etc... lights). If that fuse is good, and things like your radio and x-fer/AT lights are also out, then all signs point to the headlight switch.
Old 07-21-2010
Portuga_XJ's Avatar
Portuga_XJ Portuga_XJ is offline
headlight switch, mine did that awhile ago.
double check ur fuses also.
Old 07-22-2010
thanks all - will post back the results
Old 07-22-2010
tj'sxj's Avatar
tj'sxj tj'sxj is offline
mine did the same while i was doin lil work, turned out i pluged 2 wires togther that did not belong to each othe! they were located in the rear hatch!
Old 07-23-2010
winterbeater's Avatar
winterbeater winterbeater is offline
All electrical circuits are testable with a meter. Replacing the switch on a guess is not cool at all. Test the switch with a meter.
Old 07-23-2010
after checking the fuses with a meter I resorted to purchasing a switch for $22 and fixed the issue. Thanks all for the advice.
Old 07-27-2010
Well the switch went again. Does anyone know what could be causing this and how to troubleshoot the issue? I already checked all the fuses.
Help please!
Old 07-27-2010
CharlesS's Avatar
If the headlight/dimmer switch went bad again; it is either a poor quality switch or there is a extreme load on the switch that is causing the contacts to burn out.
1998 4.0L AX-15
Old 07-27-2010
CharlesS - Thanks for the input. What do you recommend? I would really hate to bring it in to the shop for something like this.
Old 07-27-2010
CharlesS's Avatar
Has the fuse been replaced with a larger rated fuse? You would expect that if the load were excessive to burn out contacts; it would blow a fuse too!what do you have connected to that circuit? Anything extra?
1998 4.0L AX-15
Old 07-27-2010
joe_peters's Avatar
Paying it forward
Are the contacts melted to the headlight switch?
88 Wagoneer headlights work but not dash lights AmyEllen OEM Tech Discussion 5 12-17-2008 19:41
No headlights, dash lights or tailights... tribal_4x4 OEM Tech Discussion 3 03-16-2008 19:56
No Headlights or Dash Lights - Searched TickDontPick OEM Tech Discussion 7 08-13-2006 22:50
How to remove center console, dash bezel? nosajwp OEM Tech Discussion 4 11-15-2004 19:21
Non-working headlights/tail lights BIG98XJ OEM Tech Discussion 0 05-21-2004 00:02
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
