Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old June 18th, 2010, 11:39
poomero poomero is offline
fuel rail o-rings needed
does anyone know where i can get a set of o-rings for a 4.0 fuel rail. i am going to change my injectors and want to change the fuel rail o-rings while i have it apart. napa doesn't have any nor doe jeep.
Old June 18th, 2010, 12:40
Alex E Alex E is offline
Re: fuel rail o-rings needed
winchester auto is great, you can get "standard" brand. comes in a red and black box, you might have to get two boxes though because you'll want 12 o rings for 6 injectors
Old June 18th, 2010, 12:41
if that doesn't work call kolwiess, i think its spelled like that, they are great too they have a sunnyvale and redwood city location
Old June 18th, 2010, 13:39
they said they have them. Thanks.
Old June 18th, 2010, 14:15
yeah no prob, they are a good store. i use them for pretty much anything else thats not a mod or aftermarket upgrade. what are you doing for injectors?
Old June 18th, 2010, 16:41
I am putting the ford injectors in this sunday with the help of 5-90.
Old June 18th, 2010, 18:12
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
i used the stock injector o rings on my ford injectors. i got the entire set from AZ for 7$.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Rate This Thread:
fuel rail to> fuel line connector issue? mattbred OEM Tech Discussion 22 October 6th, 2009 00:58
help needed -Fuel rail supply cdnabn49 OEM Tech Discussion 5 March 5th, 2009 19:11
Fuel injection hose, in place of fuel rail quick connects 92DripCherokee Modified Tech Discussion 7 December 5th, 2007 12:32
Needed Urgently! 94 and up HO fuel rail and regulator downshift1 Midwest Chapter 10 December 16th, 2006 00:13
im lost here ..leaking fuel from this thing on the fuel rail VegasAnthony OEM Tech Discussion 11 November 2nd, 2006 11:12
