Old May 3rd, 2010, 13:59
SrDesigner SrDesigner is offline
Speedometer Gear Install
So I get this new gear, after waiting for a couple weeks, and I'm trying to install it. The old one comes out easy enough, but I can't even force the new one into the sensor body.
It doesn't "snap" like the old one does. I don't see any "visual" differences between the old and new shafts, but I'm afraid to exert any more force than I can with my fingers...for fear that I'll create a larger problem.
I've snapped the old one in and out just to make sure I wasn't a complete idiot...and no problems with that. But this new one just flat won't go.
Any help would be appreciated,
Sr
Old May 3rd, 2010, 14:06
souske's Avatar
souske souske is offline
Salton of Stuck
Re: Speedometer Gear Install
try lubing it up maybe? or hold the body with one hand and hit the gear in with the palm of your hand. They can be stiff, but you will know when it goes.
SoCal VP
61/100 hours donated to SBNF AAT for 2015
Old May 3rd, 2010, 14:11
The original pops on and off with two finger pressure...I put my palm on the new gear and couldn't force the thing in with all my strength and I'm no sissy. It had a pretty good amount of tranny fluid on it when I started but, I guess I could try some grease on it.
Thanks for responding,
Sr
Old May 4th, 2010, 16:11
joe_peters joe_peters is offline
Hold up.
Are you changing the number of TEETH?
Read this: http://www.naxja.org/forum/showthrea...ht=speedo+gear
Old May 4th, 2010, 21:18
xjhavens's Avatar
xjhavens xjhavens is offline
If you didn't replace to o ring, do that. And use some grease. I had the same issue changing mine.
Old May 4th, 2010, 21:44
Problem doesn't lay with reinstalling the sensor, after gear install...it lay's with installing the gear INTO the sensor. Like I said the old one pops in and out with two fingers pressure. The new one, not even close.
We've had 60mph winds for the last two days so, I haven't gotten out to try again. Still leaning toward grease and a mild rap on the gear to try to seat it...
I don't have a new o-ring, but am willing to go back in a little later to put one on...My speedo is so far off it's driving me crazy.
Oh, I completely "get" the concept of rotating the sensor housing to the tooth indication...if I ever get the freaking gear to seat in the sensor housing.
Thanks Ya'll,
Sr
Speedometer Gear Wiser SoCal Chapter 7 November 8th, 2008 21:55
speedometer gear tonexj OEM Tech Discussion 0 August 12th, 2008 12:46
Speedometer Gear Blue96XJ Modified Tech Discussion 6 November 10th, 2007 07:26
Speedometer gear summitlt OEM Tech Discussion 5 March 1st, 2006 17:10
WTB '89 XJ Speedometer Gear Beagles Wanted: Private Party Only 1 February 25th, 2004 21:49
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
