Old April 17th, 2010, 17:16
BenDiesel BenDiesel is offline
fuseable link?
89 xj 4.0 auto
i broke my jeep. i get in it and it went click and no power to any thing. so i fiddle with the positive battery terminal for a while because it was a weak connection. while tightening the terminal i accidentally dropped it on the negative terminal while the engine was running and the engine stopped instantly, now im not getting any spark. any ideas?
Old April 17th, 2010, 17:18
joe_peters joe_peters is offline
Re: fuseable link?
There are fusible links in the wires attached to the large lug on the starter relay--the Renix PDC.
So, engine cranks, no spark?
Old April 17th, 2010, 17:59
Re: fuseable link?
ya cranks but no spark. didnt check to see if the injectors were getting power.
is there any way of checking the links without a hom meter?
Old April 17th, 2010, 18:24
Re: fuseable link?
You have a 12 volt test light? Hook the ground to the battery, check the PDC lug for power, If you have it then poke along the wires leading off the PDC lug to see if the links are blown.
Old April 18th, 2010, 11:17
boomhauer's Avatar
boomhauer boomhauer is offline
Re: fuseable link?
The ASD (Automatic Shut Down) relay may have blown in the PDC. -B
Old April 18th, 2010, 12:46
Re: fuseable link?
Technically "B Latch relay" for a Renix.
Old April 18th, 2010, 13:57
Re: fuseable link?
???? is this the relay that has the power going from the battery to it?
Old April 19th, 2010, 11:14
boomhauer's Avatar
Re: fuseable link?
Hey Ben, the relay that i was speaking of the "B Latch Relay" as Joe corrected me on (thanks Joe), you can tell I have a non Renix 4.0, is located in the PDC on my non-Renix and should be labelled on the lid of the PDC cover. Is there a PDC on Renix? lol
You may have blown the fuse at the front of the PDC as well, which is what i think you are referring to. It is either 100 or 125amp mega-fuse and it has a name for the life of me i can't remember what it is though. It is the master fuse for the PDC and sometimes has a cover over it and is external of the PDC itself and sits right in front. It will have battery cables to it. Am i making any sense? lol
If you have no electrical other than cranking, this may be the case or as mentioned above the B Latch.
Hopefully Joe or another Renix master will chime in. I'll probably stay out this thread as mentioned i don't know Renix, but i will keep watching, curious to see if you get her figured out and good luck. -B
Old April 19th, 2010, 13:26
5-90's Avatar
5-90 5-90 is offline
Re: fuseable link?
There is no PDC on RENIX - that's a ChryCo thing.
RENIX has the starter motor relay (goldish metal can in front of the four DIN relays, has a large 3/8" screwpost with several fusible links coming off of it) and the DIN relays behind it (I don't recall the order, but they're the B+ Latch, Fuel Pump Relay, Aircon Compressor Clutch Relay, and I can't think of the other one offhand.) All four relays are standard DIN pieces, and are generally available for ten bucks or less (ask for "Bosch/Hella" relays.)
The fusible links may easily be inspected visually - the Hypalon insulation will bubble and char if the wire inside has burned through (this may be confirmed simply by gently manipulating the wire - if it doesn't feel like there's wire in there, it's burned out. Replace, using the same length and wire gage of fusible link wire.)
Old April 19th, 2010, 13:44
Re: fuseable link?
RENIX has the starter motor relay (goldish metal can in front of the four DIN relays, has a large 3/8" screwpost with several fusible links coming off of it) and the DIN relays behind it (I don't recall the order, but they're the B+ Latch, Fuel Pump Relay, Aircon Compressor Clutch Relay, and oxygen heater relay). All four relays are standard DIN pieces, and are generally available for ten bucks or less (ask for "Bosch/Hella" relays.)
Fixed.
Old April 19th, 2010, 20:05
Re: fuseable link?
well thanks for the input guys. with the help of my friend and my electronics fsm we found the blach relay wasn't sending power to the ignition pole. a bit of poking around at the junk yard i found 3 for a total of 2.50 ! way cheaper then the 44 bucks napa wanted or the 56 action auto wanted. so it was a combo of a low charge on the batt from cranking and the relay.
thanks again
Old April 19th, 2010, 20:34
5-90's Avatar
Re: fuseable link?
Originally Posted by joe_peters View Post
Fixed.
Thanks.
"Wouldn't it suck to be an alcoholic with Alzheimer's? Imagine needing a drink, but not being able to remember where you left it..."
"You know what the beauty of Alzheimer's is? New friends every day!"
Granted, I don't have Alzheimer's. Merely post-traumatic CRS...
Old April 19th, 2010, 20:36
5-90's Avatar
Re: fuseable link?
thanks again
Erm, was that $44 or $56 for the little 1" cube relays?!? I need to find a good vendor for Bosch or equivalent and add them to the line, methinks...
I've never been happy getting a used electric anything, unless I'm going to tear it to bits and overhaul it first thing! It's not a "good deal" if the damn thing won't work...
Old April 19th, 2010, 21:36
Re: fuseable link?
no it was that much for the starter motor relay (goldish metal can in front of the four DIN relays, has a large 3/8" screwpost with several fusible links coming off of it) new from a parts store
Fuseable link for alternator DoctorPhate OEM Tech Discussion 20 December 7th, 2009 15:29
Four link rear/URF three link front shakedown pics Roxtar Advanced Fabrication and Engineering 53 November 1st, 2005 16:41
Melted Fuseable Link Noodle OEM Tech Discussion 0 March 8th, 2005 15:57
fuseable links lankchevy OEM Tech Discussion 1 February 27th, 2005 17:43
Replace Fuseable Links with Fuses HodgePodge OEM Tech Discussion 8 December 29th, 2004 18:33
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
